Page 1 of 7 1 2 3 4 5 6 7
Andy, your 470/270TF indy 440-3 results #2713605
11/07/19 10:13 AM
11/07/19 10:13 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Andy, what were the results of the 470/270 combo with the 440-3 ported? I just read it was 50hp down in power before porting.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713608
11/07/19 10:18 AM
11/07/19 10:18 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Wasn't it about 1200 HP?
Oh, sorry... must be still thinking about the 2020 Drag Pak thread... laugh2
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713615
11/07/19 10:41 AM
11/07/19 10:41 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Actually......... it was a 400-3 smoke
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2713622
11/07/19 10:56 AM
11/07/19 10:56 AM
Mt Morris Michigan
Mt Morris Michigan
My mistake. Yes 400-3. Just curious as I use the 400-3 as well and I originally suspected the heads, cam or intake for my low power woes. I no longer suspect the cam, but compression or intake as of now for the lost ponys.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713646
11/07/19 12:13 PM
11/07/19 12:13 PM
AndyF Online content
AndyF  Online Content
The 440-3 didn't work very well out of the box. Once it was ported the engine made pretty good power. There wasn't a 50 hp difference between ported and unported, more like 15 hp at peak. But it is about more than peak power, the unported intake had a roller coaster power curve while the ported one was nice and smooth. The EGTs smoothed out with the ported intake and the engine sounded better.
Re: Andy, your 470/270TF indy 440-3 results [Re: AndyF] #2713664
11/07/19 12:51 PM
11/07/19 12:51 PM
Mt Morris Michigan
Mt Morris Michigan
Good to know. Thanks andy
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713689
11/07/19 01:44 PM
11/07/19 01:44 PM
I don't even bother building serious engines anymore with a cast intake. At the minimum I'll send them to Hughes for their deep port match. If the budget allows then I send the intake to Wilson or I have a local guy do it if he has time. None of the existing Mopar intakes fit very well out of the box. Indy castings tend to be way off and so are Edelbrock. Trick Flow used to be good but the last few I've looked at were way off also.
Re: Andy, your 470/270TF indy 440-3 results [Re: AndyF] #2713697
11/07/19 02:06 PM
11/07/19 02:06 PM
Mt Morris Michigan
Mt Morris Michigan
I see. Looks like best would be to just purchase intake from Hughes with it deep ported? If my cam is installed correctly and the heads dont improve much a different intake will be in the works. TF most likely.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713699
11/07/19 02:13 PM
11/07/19 02:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Trick flow std port intake on your MW sized heads?? work
I actually think Andy did try the TF manifold on the 270 heads.
I don’t remember that combo being too special....... but there were a lot of tests, and I may be remembering it wrong.
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2713708
11/07/19 02:41 PM
11/07/19 02:41 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, I thought they could deep port match it to max wedge? My mw ports are not much bigger than the TF270 int port. There was a mopar engine builder near me MRL, used to hange out on A and B bodies. He built a guy a 470 with cast 440-1 heads, used a nonport matched standard port intake. Made over 700hp. Didn't seem to hurt it. Have you performed any studies on what's gained or lost on port matching vs not? Curious
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713710
11/07/19 02:50 PM
11/07/19 02:50 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t recall doing any testing between ootb vs port matched intake manifolds......... but.......
I did have a 557 on the dyno making about 835hp with an ootb 440-3.
I’m sure if you read thru Andy’s tests of the 270 heads, you’ll find where he tried the std port intake.
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2713729
11/07/19 03:25 PM
11/07/19 03:25 PM
Mt Morris Michigan
Mt Morris Michigan
I'll have to look again, didn't see that. I would think as long as the clylinderhead intake port is larger than the intake port, it wouldn't be very detrimental. Other way around would be a big problem.
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2713731
11/07/19 03:35 PM
11/07/19 03:35 PM
A Wilson ported M1 with standard ports worked better with my 270 heads than an OOTB Indy 400-2 intake. Once the 400-2 was ported then it worked better. The Indy 400-2 out of the box was a pig. Once it was reworked by Wilson it ran pretty well. Your results may vary. I was working with a fairly well sorted out combo. That was a pump gas 470 that was making over 750 hp. I think the best set of pulls was 780 hp. Most guys don't spend the time and money to dial in a combination like that. If you knock 100 hp off the engine then the OOTB intake probably works just fine.
Re: Andy, your 470/270TF indy 440-3 results [Re: AndyF] #2714115
11/08/19 11:40 PM
11/08/19 11:40 PM
Mt Morris Michigan
Mt Morris Michigan
What are the options for lo deck intakes with 4500 flange?
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2714236
11/09/19 01:17 PM
11/09/19 01:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why not get the ultimate Dave and go T-Ram which I plan on in the near future.....better power and distribution than any single set up.......Up the compression, get a .700ish lift solid roller and hang on............
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2714254
11/09/19 02:03 PM
11/09/19 02:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
C’mon Dave...... you’ve said “whatever it takes”....... just box that thing of yours up and send it off for porting.
Re: Andy, your 470/270TF indy 440-3 results [Re: fast68plymouth] #2714280
11/09/19 04:12 PM
11/09/19 04:12 PM
Mt Morris Michigan
Mt Morris Michigan
First things first guys. Heads are headed to Detroit next friday. Still checking all my options with these heads. Angle milling is not off the table just yet. I need to get an opinion and price from Sanchez first.
Dom, the T ram combo is still a couple yrs out, but still high on my list. The combo I'm looking at is $2500+ .
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2714290
11/09/19 05:01 PM
11/09/19 05:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I get it plus you need to know exactly what's up before moving on......
Re: Andy, your 470/270TF indy 440-3 results [Re: Thumperdart] #2714336
11/09/19 07:38 PM
11/09/19 07:38 PM
Mt Morris Michigan
Mt Morris Michigan
Re: Andy, your 470/270TF indy 440-3 results [Re: mopar dave] #2714363
11/09/19 09:41 PM
11/09/19 09:41 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I was very happy with my Indy 4500 after I got it back from Wilson
With a smaller ported head the car ran basically the same as it did with a more ported EZ and unported manifold.
So what ever they did helped for sure. Expensive though.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
