SE Headliner Board Repair #2712929
11/05/19 10:13 AM
11/05/19 10:13 AM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
I have firm bend in my original headliner board that I’m not sure how it happened but I’d like to flatten or straighten it out. Does anyone have any experience or suggestions to correct this?
Tom
68 Charger
70 Cuda
Re: SE Headliner Board Repair [Re: FC7cuda] #2712937
11/05/19 10:41 AM
11/05/19 10:41 AM
Sudbury, ontario canada
750-h2 Offline
750-h2  Offline
I had the same problem with mine. I fixed the problem with fibreglass matting. In my case the center portion of the headliner was caving in. What I did was I placed a cement block on the floor and placed the low spot of the headliner on the block making sure the headliner was completely off the ground. I then put weights on the headliner on different locations until the headliner had the right shape. Then started laying boat fiberglass matting on the headboard where it had been out of shape. I let it sit for a couple of days then removed the weights and gave it another coat of matting this time going wider as the weights were no longer in the way. This worked great for me.
Re: SE Headliner Board Repair [Re: 750-h2] #2712951
11/05/19 11:13 AM
11/05/19 11:13 AM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
That's a really good idea, 750-h2. I had read about Fiberglas repairs, and may end up doing that on this small area. Any idea if wetting this area could make it pliable and then I could reshape and let dry?
68 Charger
70 Cuda
Re: SE Headliner Board Repair [Re: FC7cuda] #2712960
11/05/19 11:35 AM
11/05/19 11:35 AM
750-h2 Offline
750-h2  Offline
You could try that first. I would use a wood working clamp with two short boards on both sides of the headliner to then straighten it out. If it works I would still fiberglass that area afterwards to make sure it stays that way. Of course all the fiberglass goes on the unseen [roof side] of headliner board..
Re: SE Headliner Board Repair [Re: 750-h2] #2713244
11/06/19 08:52 AM
11/06/19 08:52 AM
Rhode Island
jml19621 Offline
jml19621  Offline
Rhode Island
I had the same problem with my Cuda headliner. I used heavily diluted, "Elmers" white glue. I put it in a sprayed the area with a spray bottle with water in it. I got the area pretty wet. The I brushed on several coats of the, glue. It worked but I was not impressed with overall result. I thought there was a company repo these,
Here is the link, https://www.jegs.com/i/Golden+Star/...et9DV5QIVA5-fCh0ECwU5EAQYAyABEgK4wPD_BwE
Re: SE Headliner Board Repair [Re: jml19621] #2715342
11/13/19 08:22 AM
11/13/19 08:22 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I would get a hold of Dayclona and ask him to make you a fiberglass replacement. That old cardboard can be Mickey Moused but face it, it's 50 years old. It's just going to fail again.
