Solid flat tappet lifters
#2712209
11/02/19 08:24 PM
11/02/19 08:24 PM
Posts: 100 Minnesota
TrackPack
Minnesota
Looking for a recommendation on a set of solid flat tappet lifters for a cam that I want to try. I thought that tool steel would be nice, but read the following thread and decided that they may not be the best. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2402051/flat-cam.html#Post2402051Application is a 440 iron headed bracket race motor. Cam is an old Lunati grind that I planned on using with Comp 928 springs.
Re: Solid flat tappet lifters
[Re: TrackPack]
#2712213
11/02/19 08:29 PM
11/02/19 08:29 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Yep that was me, Roller in it now.
[Re: TrackPack]
#2712221
11/02/19 08:39 PM
11/02/19 08:39 PM
CSK
Pattison Texas
Thanks.
What did you end up doing to get the oiling issues corrected? Multiple things, main bearings worn, oil pump shaft bushing was REAL loose & ruined the oil pump , as of now I have 3500ish miles on it since the refresh & cam change.
[Re: CSK]
#2712266
11/02/19 10:32 PM
11/02/19 10:32 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I am real happy with Howards lifters with edm oiler hole . Used on the last flat tappet cams in my 440,505,505 Brackst raced plus daily dtiven
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: TrackPack]
#2712319
11/03/19 08:14 AM
11/03/19 08:14 AM
Posts: 287 PA
Harry's Taxi 2
PA
I have been using Trend/Barton tool steel lifters. (they're a little different than directly from trend as the body has no groove/space in the middle)
The same set have been used on 4 different cams in two different short blocks. I use either Schaffer's or Valvoline 10-30 racing oil with no additional additives.
Currently using Isky 8205 springs.....I'd have to check my notes, but I think they're around 150# closed and #430 open
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Harry's Taxi 2]
#2712337
11/03/19 10:41 AM
11/03/19 10:41 AM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I read that link posted above and my planned 3 year rebuild never happened last Winter so I lowered my shift rpm from 7000 To 6700 rpm and ran it for a forth year. Everything must be ok as it was still cranking out 6.0 passes. Still same EDM lifters and Penn Grade (old Brad Penn) oil and a zinc additive for extra insurance.
[Re: TrackPack]
#2712536
11/03/19 09:00 PM
11/03/19 09:00 PM
CSK
Pattison Texas
Thanks for the replies. I had my eye on the lifters from Barton, if they can be reused on cam changes I think they are well worth the money. Yeah, well My lifters are still perfect & could be reused on a new cam, the old cam not so good.
[Re: pittsburghracer]
#2712537
11/03/19 09:01 PM
11/03/19 09:01 PM
CSK
Pattison Texas
I read that link posted above and my planned 3 year rebuild never happened last Winter so I lowered my shift rpm from 7000 To 6700 rpm and ran it for a forth year. Everything must be ok as it was still cranking out 6.0 passes. Still same EDM lifters and Penn Grade (old Brad Penn) oil and a zinc additive for extra insurance. Tool steel lifters ?
[Re: tex013]
#2712538
11/03/19 09:02 PM
11/03/19 09:02 PM
CSK
Pattison Texas
Tex Tool steel ?
[Re: CSK]
#2712575
11/04/19 12:22 AM
11/04/19 12:22 AM
tex013
Sydney,Australia
not tool steel . And I better check my spelling better ! You could also check on classracer.com re tool steel lifter use
Tex
[Re: TrackPack]
#2712613
11/04/19 10:27 AM
11/04/19 10:27 AM
BradH
I've made switch to a solid roller, but am still curious about what combination of cam treatment & solid lifter material is getting the for street & strip use these days. - Standard cast iron cam core - Standard cast iron cam core + nitriding - Standard lifter + EDM hole - Tool steel lifter + EDM hole (assuming all the tool steel lifters have the EDM holes) What I think I've heard between here and SpeedTalk is that tool steel lifters and nitrided cams are a bad combo. Now I'm wondering if tool steel lifters are simply a bad choice for long-term street use, even for non-nitrided cams. What about standard EDM lifters and nitrided cams?
[Re: BradH]
#2712655
11/04/19 12:30 PM
11/04/19 12:30 PM
CSK
Pattison Texas
I've made switch to a solid roller, but am still curious about what combination of cam treatment & solid lifter material is getting the for street & strip use these days. - Standard cast iron cam core - Standard cast iron cam core + nitriding - Standard lifter + EDM hole - Tool steel lifter + EDM hole (assuming all the tool steel lifters have the EDM holes) What I think I've heard between here and SpeedTalk is that tool steel lifters and nitrided cams are a bad combo. Now I'm wondering if tool steel lifters are simply a bad choice for long-term street use, even for non-nitrided cams. What about standard EDM lifters and nitrided cams? All I know is I used Tool steel lifters with EDM on a non treated cast iron cam, That is how Trend & Howards said to do it, for the money I wasted I could have gone roller to begin with.
[Re: TrackPack]
#2712694
11/04/19 02:21 PM
11/04/19 02:21 PM
Posts: 1,178 Indy
FlyFish
Indy
I did it backwards...I went from a solid roller, to solid cam with Howards EDM lifter (with the oil hole). With the oil through capability of the lifters (and oil through push rods), my push rods look much better this year. In previous years I was getting bluing at the push rod cups on a few....it was not good.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
