Re: Show me your homemade 4bbl kickdown extensions. BB
[Re: BurntOrange]
#271182
03/30/09 11:23 AM
03/30/09 11:23 AM
Posts: 3,908 Oregon
hooziewhatsit
IIRC, it's 5/16" fine thread. I couldn't find any all thread in that size/pitch, so I had to cut a bolt, then cut the KD, and bolt the new piece in the middle. Doesn't look that great, but it works for me. I can get a picture if you want one.
[Re: hooziewhatsit]
#271183
03/30/09 11:28 AM
03/30/09 11:28 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I just cut and weld in whatever's needed. sorry
[Re: AndyF]
#271185
03/30/09 02:37 PM
03/30/09 02:37 PM
Posts: 1,756 London, England
Gavin
London, England
I extended my vertical linkage by welding in a section of bolt. I also had to do the same to the horizontal linkage, and I took the pic below to show the before and after.......but in your case it shows you what I had on it beforehand - an extension I'd had made up years ago, with a lock nut to keep the length once set (top left). You could do this to achieve what you want. (I prefer the welded in bit!)
