Carter BBD Question? #2711784
11/01/19 06:42 AM
11/01/19 06:42 AM
Coastal Maine
Mr onetwo Offline OP
Coastal Maine
I am rebuilding a Carter BBD to go on my 1970 Fury III convertible with a 318. It is a #4608s from a '69 Fury.I have the proper #346C SMP kit for it.The inlet check ball for the accelerator pump has a retainer on it that is not shown in any literature, factory or otherwise. How do I remove this retainer cage to replace the ball without damaging the carb and is it even necessary? Or should I just leave it alone and not replace the ball at all?
Re: Carter BBD Question? [Re: Mr onetwo] #2711792
11/01/19 08:25 AM
11/01/19 08:25 AM
PA
70Duster Offline
70Duster  Offline
PA
Leave it alone and do not replace the ball at all.
