92 Ramcharger cold start #2711170
10/30/19 10:47 AM
10/30/19 10:47 AM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I have a 92 Ramcharger Canyon Sport plow truck that has a 5.9 fuelie that won't idle high when cold. If I keep me foot in it for a couple of minutes it will stay running, but if I start in and let of the gas it will die. What controls the idle at cold start?
JB Rhinehart, Realist
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2711317
10/30/19 04:38 PM
10/30/19 04:38 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
isn't there a throttle position sensor?
1981 Dodge D150 360 auto
Re: 92 Ramcharger cold start [Re: basketcase] #2711382
10/30/19 07:24 PM
10/30/19 07:24 PM
Central NY
GarageDodge Online content
GarageDodge  Online Content
Central NY
water temp sensor for the pcm,must read correct temp& idle control valve or motor control idle speed,hot or cold.
Re: 92 Ramcharger cold start [Re: GarageDodge] #2711443
10/30/19 10:28 PM
10/30/19 10:28 PM
Rhinotruck
Rhinotruck
I was looking at Rock Auto and it seems there are a few sensors that could cause this including the TPS. I am hoping someone would have been through this instead of just throwing parts at it. I am not at all familiar with Magnum engines. It runs find after it is warmed up.
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2711516
10/31/19 08:39 AM
10/31/19 08:39 AM
Central NY
Central NY
you need a scanner to check water temp when cold,should be close to air temp.Start with that,it tells pcm what mixture&idle speed should be.Alos check air temp sensor,should be within 10-12 degrees of water temp when cold.
Re: 92 Ramcharger cold start [Re: GarageDodge] #2711711
10/31/19 07:36 PM
10/31/19 07:36 PM
Guitar Jones Online laugh2
If the battery has died or recently replaced the first thing to do is clean the throttle body. The PCM will lose it's memory and start over as if it's new so it expects to see a certain amount of air flow at idle. It the throttle body is dirty it doesn't have that. Plus cleaning the throttle body is free.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 92 Ramcharger cold start [Re: Guitar Jones] #2711763
10/31/19 11:43 PM
10/31/19 11:43 PM
Rhinotruck
Rhinotruck
Interesting. I will do just that!
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2711939
11/01/19 05:04 PM
11/01/19 05:04 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Do those have an IAC motor on the throttle body? I've seen those get carboned up and stop working properly.
Re: 92 Ramcharger cold start [Re: Rhinodart] #2712022
11/02/19 06:42 AM
11/02/19 06:42 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had a similar problem with my Jeep 4.0 and it was the idle air motor. But getting it on a scanner to take a look at coolant temp certainly wouldn't hurt.
68 Barracuda Formula S 340
Re: 92 Ramcharger cold start [Re: Bad340fish] #2713503
11/06/19 08:52 PM
11/06/19 08:52 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Could be the idle air control.
Helpful video here: Video
I have to give a mention to this Guy on Youtube, "Splelunkerd" that his 2nd Gen Ram videos are the best I've seen. He gives really clear instructions, lots of common sense style repair tips, and is smart as hell; worth subcribing or favoriting in your browser. twocents
This Fellow takes the whole thing apart, but I just pulled mine out from the back, cleaned it with brake cleaner and was good as new.
Usually, Rhino if it's the IAC the idle will wander when it's cold. Hopefully, this is what your issue is (free fix up)
Mo' Farts
Moderated by "tbagger".
Re: 92 Ramcharger cold start [Re: Grizzly] #2716922
11/17/19 09:40 PM
11/17/19 09:40 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
This being a 92 360, it should not be a magnum, 92 360 was TBI yet, Look on the drivers side of the of the throttle body there is a motor with a plunger, have a helper turn key off and on, this should move the plunger in and out, if it does not, you most likely need a new idle control motor, these were bad failing .
Re: 92 Ramcharger cold start [Re: Ramtough] #2717274
11/18/19 06:32 PM
11/18/19 06:32 PM
Rhinotruck
Rhinotruck
You are right, here are pictures of the passenger side of the TBI. I will check the other side now. I thought it might be one of these sensors...
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2718299
11/22/19 05:33 AM
11/22/19 05:33 AM
Well first things first, the MAP sensor is missing the vacuum hose.
Re: 92 Ramcharger cold start [Re: Guitar Jones] #2718454
11/22/19 08:17 PM
11/22/19 08:17 PM
Rhinotruck
Rhinotruck
The hose was going to the air cleaner, is it not supposed to go there? shruggy
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2718477
11/22/19 09:42 PM
11/22/19 09:42 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Nope. Straight to manifold vacuum. The MAP sensor is basically an electronic vacuum gauge for the computer.
Re: 92 Ramcharger cold start [Re: volaredon] #2719204
11/25/19 03:14 PM
11/25/19 03:14 PM
Rhinotruck
Rhinotruck
OK, I will check to see where the hose is supposed to come from, thanks!
A-Body's RULE!
Re: 92 Ramcharger cold start [Re: Rhinodart] #2719223
11/25/19 04:29 PM
11/25/19 04:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
i saw that also but it would be super rich if the map sensor vac line was off, which would make it run better cold. That might be open for a barometric reading?
Re: 92 Ramcharger cold start [Re: Rhinodart] #2719639
11/27/19 04:35 AM
11/27/19 04:35 AM
Santa Clara, CA, USA
altair18 Offline
altair18  Offline
Were you able to finish it?
Trying out bilstein shock and I'm very pleased how easy and smooth it is to drive my pickup in rocky terrain.
