Re: Valley tray for victor head and B block [Re: BradH] #2711290
10/30/19 03:25 PM
10/30/19 03:25 PM
AndyF Online content
AndyF  Online Content
Originally Posted by BradH
No more RB Victor plate?
RB Victor valley plates are out of stock and I don't plan to build anymore. Victor stuff sells very slowly compared to parts for the Trick Flow heads so as they say in business school; I'm adjusting my inventory mix.
Re: Valley tray for victor head and B block [Re: Jeremiah] #2711297
10/30/19 03:54 PM
10/30/19 03:54 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Originally Posted by Jeremiah
I might have missed it, but is something wrong with the regular bolt on valley pan?
I'm on my "third" Edelbrock valley pan since 2013. For whatever reason, heat cycles? crankcase pressure?, I've had two that cracked at the 90 degree bend and started leaking. Also, the edge above where it bolts to the head becomes distorted. I just bolted on the last new one I had, because I was in a hurry. Will order one of Andy's plates next. I got more time out of the last one by running a bead of RTV down the inside of the bend. twocents I have kind of a love/hate relationship with these heads. The couple of contingency checks Edelbrock sent me help with the love portion biggrin
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Valley tray for victor head and B block [Re: AndyF] #2711298
10/30/19 03:59 PM
10/30/19 03:59 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
You must have posted this while I was writing my previous post. RB here so, I'll probably end up making one, just won't be quite as pretty.
Re: Valley tray for victor head and B block [Re: AndyF] #2711421
10/30/19 09:31 PM
10/30/19 09:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Understood, just not expected.
Re: Valley tray for victor head and B block [Re: BradH] #2711467
10/31/19 12:35 AM
10/31/19 12:35 AM
Did you want to buy one or did you already get one. I remember talking about it at one point but I've forgotten if I ever sent you one or not. If you really want one I can send you a CAD file and you can have a local shop build one. Not a super difficult part to make for someone with a CNC vertical mill.
Re: Valley tray for victor head and B block [Re: AndyF] #2711488
10/31/19 06:33 AM
10/31/19 06:33 AM
BradH Offline
BradH  Offline
It's a really nice part that didn't fit into the budget when we spoke (and still doesn't, to be honest), so I put it on my wish list for future purchases.
Not sure if Hughes has any left in stock... may give 'em a call just to see and go from there. I know it won't fit w/o mods, since I had to make the Edelbrock tray into a 3-piece setup to narrow it enough to work.
Re: Valley tray for victor head and B block [Re: BradH] #2711557
10/31/19 10:54 AM
10/31/19 10:54 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would think a weld bead along each corner would keep it from cracking at the brake line on each side? Does this engine have a vacuum pump by chance?
Re: Valley tray for victor head and B block [Re: BradH] #2711562
10/31/19 11:01 AM
10/31/19 11:01 AM
A solid plate would be a lot cheaper but then you have to peel it off to get to the lifters. A custom solid plate could be made to match the width of your narrowed setup without too much trouble.
Re: Valley tray for victor head and B block [Re: Jeremiah] #2711641
10/31/19 02:39 PM
10/31/19 02:39 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
No vacuum pump, header evac only.
Re: Valley tray for victor head and B block [Re: AndyF] #2711653
10/31/19 03:17 PM
10/31/19 03:17 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Looks like you were directing at Brad but, my plan was to transfer pattern from Edelbrock tray to .375 alum plate and finish out with my old mill sneaking up on width. I know a guy that knows a guy that does CNC milling. I should have bought one of yours when they were available.
Re: Valley tray for victor head and B block [Re: MoParFish] #2711852
11/01/19 11:37 AM
11/01/19 11:37 AM
BradH Offline
BradH  Offline
Someone on eBarf makes an aluminum cover that IMO is the same basic design as the Edelbrock thin steel cover, IIRC. But if it doesn't fit, it'll be more difficult to modify cleanly. sawzall + hammer
