Re: FAST - Ed Cook goes 10.26 @ 131.70
[Re: topside]
#2710767
10/28/19 08:36 PM
10/28/19 08:36 PM
Posts: 3,113 Michigan
A727Tflite
What a nice - and killer - piece that car is. Incredible on so little tire.
I'm surprised the scoop doesn't help, but I'm assuming air cleaners would have lids off & air horns foam-sealed to the hood. Good point, I forgot they have to run with air cleaners in place. But that thing is still getting with the program. Amazing 60 foots.
[Re: XXHEMI]
#2710769
10/28/19 08:44 PM
10/28/19 08:44 PM
A727Tflite
Thanks Guys!
I have not run the car a lot in the past two years because of one thing or another and was almost loosing interest.
The car is running good. But I still have a lot more work to do and I think it will go faster. The car weighs 3352 and I weigh 350? no super lightweight package. Maybe next year I can get my son to drive.
(Trans man) you are correct the hood should not be on the car and believe it or not it has no advantage at all for this car except looks. Flat hood will be back on in the spring.
Dwayne the sixty foot on this pass was 1.54 which is it's best on the small tire. At the Yellow Bullet this year on slicks the car went 10.12@136 with 1.49 sixty
Since you are certainly in the know on this class - do the cars go through weigh-in as part of tech? How about weight distribution check ? Just wondering as I have been thinking of running something and when I read the rules I don’t be see any mention of weight. Thanks. And congrats on that performance.
[Re: A727Tflite]
#2710782
10/28/19 09:19 PM
10/28/19 09:19 PM
Posts: 731 NY
XXHEMI
NY
No Weight rules.
Make it as light as you can!.
[Re: XXHEMI]
#2710800
10/28/19 10:29 PM
10/28/19 10:29 PM
Posts: 4,715 Wichita
GY3
Wichita
Can I be nosy and ask how much ballast and where/how it's located?
[Re: XXHEMI]
#2710805
10/28/19 10:41 PM
10/28/19 10:41 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
No Weight rules.
Make it as light as you can!. Where do you think FMJ gets all his weight reduction ideas from? ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
'71 Duster '72 Challenger '17 Ram 1500
[Re: A727Tflite]
#2710888
10/29/19 10:34 AM
10/29/19 10:34 AM
Posts: 3,529 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Still curious how he gets to run a scoop.
I wonder as well but I think NHRA allows them on all the 63 and 64 Max Wedge and Hemi cars, plus T/A and AAR hoods on a lot of engine combos that I don't remember having them. Same thing with single four barrel hemis, I don't remember seeing any on the street or the drag strip back in the day All I can guess is that Chrysler must have given some pretty vague documentation that is being interpreted in a way favorable to Mopar brands. This is all fine with me as the other manufactures have done the same thing.
[Re: gregsdart]
#2710890
10/29/19 10:38 AM
10/29/19 10:38 AM
340Cuda
Tulsa, Oklahoma
I am guessing that the max wedge exhaust manifolds help a bunch? Still, very impressive!!! KInd of a mixed blessing, I have been told the exhaust systems weigh about two hundred pounds and I know from personal experience they throw off a lot off heat under the hood.
[Re: XXHEMI]
#2710907
10/29/19 11:39 AM
10/29/19 11:39 AM
Posts: 117 NW Indiana
powertrip
NW Indiana
Thanks Guys!
Wow that car is flying! And it's doing it at a higher weight than I would have guessed! Ed, is there anything about that combo you would share with us? Specifically, what has been done with that intake manifold and carbs? Everyone says that intake will cost 100hp over a good 4 barrel intake. Also, curious to which rear end you are running?
[Re: Chuck@Best_Machine]
#2711051
10/29/19 10:38 PM
10/29/19 10:38 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
Amazing car! Do they typically run factory carbs (i.e. AVS, AFB, Holley 4160 etc) or can you cheat and use an Edelbrock or holley hp place of the OEM carb?
[Re: BradH]
#2711153
10/30/19 10:14 AM
10/30/19 10:14 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Very impressive considering everything they have to work with! I can't imagine the R&D that goes into making one of these FAST cars work like this.
[Re: an8sec70cuda]
#2711163
10/30/19 10:40 AM
10/30/19 10:40 AM
Posts: 5,160 Texas
dannysbee
Texas
Not to take anything from Ed as his car is one of my favorites. Tom Hoover and his son built a 1964 Plymouth to run in pure stock. It also is a max wedge and runs on the same tires. With unported heads no stoker and a flat tapper 520 lift cam runs mid 11’s at 120 mph Got to love a max wedge.
Getting old just means you were smarter than some and luckier than others.
[Re: FurryStump]
#2711234
10/30/19 01:03 PM
10/30/19 01:03 PM
Posts: 1,853 South Bend
John Brown
South Bend
Congrats Ed! In the past some people tried to treat the tires with chemicals, but at this point I don’t think that it is done and certainly not wide spread. The tires are very worn if not bald. I can verify that. Soaking these tires is a waste of time. And money. The rubber on reproduction bias plys is already soft, and treating them makes the rubber so soft that it will almost fall off when doing a burn out. Totally worthless.
[Re: Jeremiah]
#2711260
10/30/19 02:03 PM
10/30/19 02:03 PM
Posts: 731 NY
XXHEMI
NY
Amazing car! Do they typically run factory carbs (i.e. AVS, AFB, Holley 4160 etc) or can you cheat and use an Edelbrock or holley hp place of the OEM carb? Everything but the block is supposed to be factory OEM parts with correct part numbers. You can do what ever possible to make your parts better as long as they keep there stock appearance. I do not treat the tires. I shave them down to the wear bars and start burning em up from there. A good set of tires are priceless!
[Re: XXHEMI]
#2711274
10/30/19 02:45 PM
10/30/19 02:45 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Amazing car! Do they typically run factory carbs (i.e. AVS, AFB, Holley 4160 etc) or can you cheat and use an Edelbrock or holley hp place of the OEM carb? Everything but the block is supposed to be factory OEM parts with correct part numbers. You can do what ever possible to make your parts better as long as they keep there stock appearance. I do not treat the tires. I shave them down to the wear bars and start burning em up from there. A good set of tires are priceless! So you are saying it’s an aftermarket block with stock pistons, cranks, rods, cams, intake manifolds, carbs, etc etc, but they can use a tire and compound that is modified. If so that’s super fast for that combo. Even for Fall type weather at an east coast track. Congratulations
