felpro headgasket limits?? #271037
03/29/09 09:54 PM
03/29/09 09:54 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
Is there a comp. ratio that you should upgrade to cometics??does felpro have it's limits??small block if it matters.
Re: felpro headgasket limits?? [Re: moretoys] #271038
03/29/09 10:14 PM
03/29/09 10:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
13.0:1 has been no problem.
Re: felpro headgasket limits?? [Re: topside] #271039
03/29/09 11:16 PM
03/29/09 11:16 PM
Arizona
Chris'sBarracuda Offline
Arizona
The 10 head bolts are more of a problem than the Fel Pros..
Chris..
Re: felpro headgasket limits?? [Re: moretoys] #271040
03/29/09 11:51 PM
03/29/09 11:51 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
We have been over 15-1 with 1008 a bunch of times, race only though.
Hope that helps.
Rick
Re: felpro headgasket limits?? [Re: Domino1609] #271041
03/30/09 12:17 PM
03/30/09 12:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Hope that helps.
Rick
What procedure are you using?
Re: felpro headgasket limits?? [Re: moretoys] #271042
03/30/09 01:54 PM
03/30/09 01:54 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I've ran 8553PT (comes in Fel-Pro kit) with iron heads @ 13.1:1 and a good bit of
summer months detonation. No head gasket problems. (340, 269º @ .050" cam)
