NOS Block 2468330-M ID? #2710159
10/26/19 01:39 PM
10/26/19 01:39 PM
Terre Haute Indiana
PJSIXPACK Offline OP
Terre Haute Indiana
I am being offered a NOS block with a Casting number of 2468330-M It has 8A23 with a 27 under it It is a 4.25" bore with 2 bolt mains. 413, 426 Wedge or a 440 block? It has the extra material around the Lifter bores. Thank you in advance. He is asking $2,000.00. PJ
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710163
10/26/19 02:05 PM
10/26/19 02:05 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What do the flat pad stamps on the top front of the block say?
Re: NOS Block 2468330-M ID? [Re: stumpy] #2710172
10/26/19 02:33 PM
10/26/19 02:33 PM
Terre Haute Indiana
Terre Haute Indiana
I have to run to work and I will get a picture. I accidentally deleted my pictures on my phone's messages.
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710177
10/26/19 02:53 PM
10/26/19 02:53 PM
central il.
second 70 Offline
second 70  Offline
central il.
That block # should be a hemi or wedge mega block. They have cross bolted mains. If it has mopar cast on it is a siamese block if not a water block. That would be a steal! These blocks are both hemi mega blocks but the wedge would be the same.
Re: NOS Block 2468330-M ID? [Re: stumpy] #2710192
10/26/19 04:18 PM
10/26/19 04:18 PM
Terre Haute Indiana
Terre Haute Indiana
Here are the numbers that I have found.
Re: NOS Block 2468330-M ID? [Re: second 70] #2710193
10/26/19 04:20 PM
10/26/19 04:20 PM
Terre Haute Indiana
Terre Haute Indiana
Thank you. It doesn't say MOPAR. The water block would be better for my use for sure.
Re: NOS Block 2468330-M ID? [Re: stumpy] #2710194
10/26/19 04:24 PM
10/26/19 04:24 PM
Terre Haute Indiana
Terre Haute Indiana
H2499 244
Re: NOS Block 2468330-M ID? [Re: stumpy] #2710197
10/26/19 04:37 PM
10/26/19 04:37 PM
Terre Haute Indiana
Terre Haute Indiana
H2499 244. Sorry I didn't do the Quote above.
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710293
10/27/19 01:27 AM
10/27/19 01:27 AM
That looks like a early Mega wedge water block to me twocents
if you buy it I would have it sonic tested first before deciding what to do with it.
One of the local ex ,Mopar drag racers (he retired due to health reasons) had several of those blocks and had one split a cylinder wall bore out to 4.500, he ran several of the same blocks at 4.440 and didn't have any cylinder wall failures at that size work
IHTHs thumbs
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710339
10/27/19 10:46 AM
10/27/19 10:46 AM
central il.
second 70 Offline
second 70  Offline
central il.
My guess is it's a P5007671 wedge mega block. Might be a unfinished block I can't tell from pictures if lifter bores are finished. It is a Motor Castings foundry block. It's the only one I found listed with 2 bolt mains. Zippy is the guy that would know more but I haven't seen him post in a while.
Mike
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710348
10/27/19 11:17 AM
10/27/19 11:17 AM
central il.
second 70 Offline
second 70  Offline
central il.
The extra material around lifter bores is normal for a mega block.
Re: NOS Block 2468330-M ID? [Re: Cab_Burge] #2710377
10/27/19 01:13 PM
10/27/19 01:13 PM
Terre Haute Indiana
Terre Haute Indiana
One of the local ex ,Mopar drag racers (he retried due to health reasons) had several of those blocks and had one split a cylinder wall bore out to 4.500, he ran several of the same blocks at 4.440 and didn't have any cylinder wall failures at that size work
IHTHs thumbs
Thank you. As far as you know, can it be bored to 4.32 or 4.350 safely?
Re: NOS Block 2468330-M ID? [Re: second 70] #2710378
10/27/19 01:14 PM
10/27/19 01:14 PM
Terre Haute Indiana
Terre Haute Indiana
Mike
Thank you, much appreciated. PJ
Re: NOS Block 2468330-M ID? [Re: second 70] #2710383
10/27/19 01:50 PM
10/27/19 01:50 PM
Terre Haute Indiana
Terre Haute Indiana
Mike
So is the P5007671 a Max Wedge block rather than a 440?
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710391
10/27/19 02:47 PM
10/27/19 02:47 PM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=PJSIXPACK So is the P5007671 a Max Wedge block rather than a 440?
No not neither. It's an RB performance block.
Re: NOS Block 2468330-M ID? [Re: second 70] #2710401
10/27/19 03:38 PM
10/27/19 03:38 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
That is a 1998 casting.
Re: NOS Block 2468330-M ID? [Re: PJSIXPACK] #2710484
10/27/19 09:51 PM
10/27/19 09:51 PM
IHTHs thumbs
Have it sonic tested first before deciding twocents
One of my customers bought one of the early Hemi Mega blocks rough bored to 4.180, he wanted it to make it into a pump gas blown Hemi motor with a 10-71 roots blower with two big Dominator blower carbs, I had it sonic tested first and we decided to bore it to 4,25 and increase the stroke from 3.75o to 4.375 to get more C.I. work
On your deal I would leave at least .200 wall thickness for future builds to start with up
Check and think twice before deciding thumbs work twocents
Re: NOS Block 2468330-M ID? [Re: Dartman440] #2710619
10/28/19 01:36 PM
10/28/19 01:36 PM
Terre Haute Indiana
Terre Haute Indiana
Thank you.
Re: NOS Block 2468330-M ID? [Re: second 70] #2710620
10/28/19 01:37 PM
10/28/19 01:37 PM
Terre Haute Indiana
Terre Haute Indiana
So with it being rough bored from the Factory to 4.25 can I have it taken out to 4.32?
Re: NOS Block 2468330-M ID? [Re: Cab_Burge] #2710621
10/28/19 01:40 PM
10/28/19 01:40 PM
Terre Haute Indiana
Terre Haute Indiana
IHTHs thumbs
One of my customers bought one of the early Hemi Mega blocks rough bored to 4.180, he wanted it to make it into a pump gas blown Hemi motor with a 10-71 roots blower with two big Dominator blower carbs, I had it sonic tested first and we decided to bore it to 4,25 and increase the stroke from 3.375 to 4.375 to get more C.I. work
Thank you. I will have it Sonic tested before I decide to buy. Is the $2,000 a decent price for the block?
