Where to get a horn button? #271021
03/29/09 09:40 PM
03/29/09 09:40 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
I need to get the horn button center for my Roadrunner. The wheel is the three spoke plastic with chrome half ring horn button. Has a padded vinyl center with no logo. Where can I get one new if possible? I need a black one. Thanks!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Where to get a horn button? [Re: itali83] #271022
03/29/09 09:44 PM
03/29/09 09:44 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I don't know of anyone making those, but you may be in luck as one was just listed tonight in the 70 and back b body parts section here on Moparts for $25. Check it out.
Re: Where to get a horn button? [Re: rrunner] #271023
03/30/09 02:03 PM
03/30/09 02:03 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
No new spoke covers being reproduced for any of the Mopar wheels, only the center caps for the 68-70 woodgrain wheels and the rimblow wheels. We do have the new Road Runner center emblems and Dodge emblems if you need. They fit nearly all of the wheels from 68 to the mid 70's. Here's one in one of our new woodgrain wheel center caps.
When you're looking for the spoke covers, be sure to look for worn areas around the end of the spoke where your thumb would rub off the grain every time you blow the horn. Very common problem with any of the vinyl spoke covers. Also keep in mind that the 70 wheel has a different spoke cover than the 68-69 even though they look almost identical at first glance.
Re: Where to get a horn button? [Re: plumbeeper] #271024
03/30/09 07:52 PM
03/30/09 07:52 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
I don't need the chrome horn ring/spokes. I just need the center padded piece. Will that horn button you show fit my wheel or only woodgrain wheels? Thanks for the reply.
Re: Where to get a horn button? [Re: itali83] #271025
03/30/09 07:59 PM
03/30/09 07:59 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
That is for woodgrain only as is what he is talking about. Did you look in the parts section? The one listed is dark blue, but I wouldn't think twice about dying it black if SEM dye is used, you will never tell the difference and it won't fade or peal if applied correctly.
Re: Where to get a horn button? [Re: rrunner] #271026
03/30/09 10:08 PM
03/30/09 10:08 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
yeah I looked and saw it. Now i'm trying to decide if I want the horn button that I see in a lot of 66-67 plymouths with the same wheel but the center cap is metal with the plymouth logo in the middle. I kinda like that better than the plain vinyl one I had stock. Decisions decisions!
Re: Where to get a horn button? [Re: rrunner] #271027
03/30/09 10:11 PM
03/30/09 10:11 PM
plumbeeper Offline
plumbeeper  Offline
My mistake, I thought you were talking about one of these...
