Whose 727 street/strip converters are you using?
#2709518
10/23/19 01:24 PM
10/23/19 01:24 PM
BradH
I have the same Dynamic 9.5" that I bought in '99(?) and it's still in good shape given how little my car's been running over the years. However, it was spec'd for the car when it was making maybe 550 HP and running very low 11s. The converter still seemed to work well w/ the 50+ HP increase that put the car into the mid 10s, so I was happy. However, the new engine is an easy 100+ HP more than the converter was spec'd for originally in '99. It's still going to be my baseline when the car is back together, but at some point I a$$ume it's either going to need to be re-configured for the new engine... or perhaps I'll want (need?) to change to another converter. So, as my subject line states, whose 727 street/strip converters are you using?
Re: Whose 727 street/strip converters are you using?
[Re: BradH]
#2709549
10/23/19 02:58 PM
10/23/19 02:58 PM
Posts: 4,206 New York
polyspheric
New York
The question is "how much torque does the new engine make at the observed stall speed?" It may have less than the original engine (later intake closing = lower CCP) and will stall lower despite the higher peak power.
If the stall torque is higher, the stall speed will increase (duh) by the ratio of (new torque ÷ old torque)^.5 RPM = K × (T^.5) Just using easy numbers: Stall now 3,500, new torque 550, old torque 500 (550 ÷ 500)^,5 = 1.0488, × 3,500 = 3,671 RPM new stall Stall now 3,500, new torque 600, old torque 500 Same math = 3,834 RPM new stall
Whether this helps or hurts launch...?
Boffin Emeritus
[Re: polyspheric]
#2709564
10/23/19 03:35 PM
10/23/19 03:35 PM
BradH
Whether this helps or hurts launch...? Converter flashed to ~4500 from 2000 launch w/ old engine combination, so I highlighted the #s at 4500 for comparison. Your formula shows about a 4600 stall w/ additional torque.
[Re: BradH]
#2709577
10/23/19 04:26 PM
10/23/19 04:26 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Brad , I ran a similar Dynamic/Lupo to you for years stalled around 48/4900 . This was with both 440 and 505 footbraking . Now with transbrake I have a A1 Performance 8" unit , stalled at 5800 with original 505 and 440 . When I went TF270 head stall went to 6000 , but car went 0.25 faster so the heads obviously helped the motor HP wise. Drives fine daily . Even drove to a race in Mildura on the other side of the state - 12 1/4 hours on the highway no dramas . Tis was 2 weeks ago .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2709590
10/23/19 05:14 PM
10/23/19 05:14 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I have loads of street miles on a Turbo Action 8" 4500 when I had my 727. My 904 had a 8" 4800 until the snout broke but that is getting repaired. The 4500 behind the 727 flashed to about 5500 and the 4800 with the 904 flashes to 6400. I did 5 drag weeks with the 727 converter and 1 with the 904, car weight on the road for drag week is around 4000ish.
The street manners of them don't bother me at all.
68 Barracuda Formula S 340
[Re: BradH]
#2709606
10/23/19 06:29 PM
10/23/19 06:29 PM
polyspheric
New York
That's not "my formula", it's the one the transmission and converter manufacturers use.
Boffin Emeritus
[Re: BradH]
#2709664
10/23/19 09:37 PM
10/23/19 09:37 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
Turbo Action or PTC, never had any issues with either one.
The only Carbs I care about are under the hood!
[Re: calrobb2000]
#2709705
10/24/19 06:29 AM
10/24/19 06:29 AM
BradH
hi ,
the dynamic worked good for 20 years and you want to know where to get a converter ?
My Dynamic has worked very well so far. My friend's sucked. Nobody hits 100%, and converter tech & good builders can change over 20 years. If the new engine and the old converter aren't a good match, I'd like to know what other people's experiences have been.
[Re: BradH]
#2709733
10/24/19 09:16 AM
10/24/19 09:16 AM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
For my A518 I had PATC custom build mine, told them my engine combo & they nailed it, so far so good, 3500miles of abuse .
[Re: Dragula]
#2709926
10/25/19 07:39 AM
10/25/19 07:39 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
FTI - great Service! Switched from a 9.5" PTC with 3200 stall to a 9.5" FTI with 3500 stall. Day and night difference! Much better.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: BradH]
#2709973
10/25/19 11:24 AM
10/25/19 11:24 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
[quote=calrobb2000] hi ,
the dynamic worked good for 20 years and you want to know where to get a converter ? My Dynamic has worked very well so far. My friend's sucked. Nobody hits 100%, and converter tech & good builders can change over 20 years. If the new engine and the old converter aren't a good match, I'd like to know what other people's experiences have been. [/quote ]by your power numbers i would geuss your new combo will want a 7000 to 7200 shift and 6200 stall. As low as 5200 may work well. I would run what you have. I didn't see a lot of change fron 5500 to 6000 stall on my deal. So the problem becomes; if you mess with it you may go backwards. Test the car with the old one and if you want to know if a change is needed buy a new one to compare.
[Re: Dragula]
#2709975
10/25/19 11:25 AM
10/25/19 11:25 AM
BradH
ATI here......Getting one for a big engine like mine wasn't easy....Love it. ATI is in Maryland about 60 miles from me, but I've never done any business with them. Dynamic is in Delaware about 120 miles from me. If there are other "close" converter companies, I don't know of them. And until what I have now is tested again, this is all "for informational purposes only."
[Re: Hemi Allstate]
#2710355
10/27/19 11:52 AM
10/27/19 11:52 AM
Posts: 1,237 North Central, Indiana
Roughbird72
I am using a 9.5" PTC that they built for my combination and street / strip . I have no complaints . But, It would be interesting to try a higher stall . Call PTC and see what they can do. I sent my 9.5" back to them after 13 years of running it, $150 + shipping to polish the hub and a refresh.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2710385
10/27/19 01:58 PM
10/27/19 01:58 PM
gregsdart
I used an A & A 10 inch medium stall behind my 408 Dart motor. 517 tq at 4600 and it stalled 4,000. There are three stall versions, about 400 rpm apart. Mine was the middle one. It had decent lockup. 2600 rpm at 60mph with 27. Inch tires and 3.55 g e ars. $700.
[Re: gregsdart]
#2710463
10/27/19 08:42 PM
10/27/19 08:42 PM
Posts: 12,073 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In my previous posts, I said that I had a 9" that I had originally gotten from PTC. But I see that they actually have it listed as a 9 1/2".
Lenny had told me that I needed a larger converter to get me where I wanted but that meant the elusive 11" core was needed.
Is it possible that the 9", 9 1/2", and 10" converters being mentioned here are in reality based on the same core?
Master, again and still
[Re: DaveRS23]
#2710494
10/27/19 11:02 PM
10/27/19 11:02 PM
Posts: 4,672 Wichita
GY3
Wichita
I run a Turbo Action 11" with 7/16 thread flexplate bolt upgrade (I couldn't keep the 5/16 thread bolts to stay tight despite being arp and loctited). 2800 rated stall as I recall.
Surprisingly, it has run a 1.37 60 ft.
[Re: bobby66]
#2710517
10/28/19 01:07 AM
10/28/19 01:07 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I also run a Dynamic 9-1/2”. To the OP, I’d send it back to Lupo and explain to them exactly how the engine and car has changed. No one will know that converter better than them.
[Re: StealthWedge67]
#2710541
10/28/19 08:28 AM
10/28/19 08:28 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I've used Atlantic Coast Converters for the past 15+ years w/ great results.
[Re: DaveRS23]
#2710554
10/28/19 09:53 AM
10/28/19 09:53 AM
BradH
Not from what I have seen... but I ain't in the converter biz, either.
[Re: BradH]
#2710558
10/28/19 09:58 AM
10/28/19 09:58 AM
an8sec70cuda
If I'm not mistaken, I think the 9" and 9.5" converter are the same. I remember my converter builder mentioning that, but it's been years ago. He's always built 9" converters for my stuff.
Brad...FWIW, my guy really likes ATI and buys a lot of parts from them.
#2710560
10/28/19 09:59 AM
10/28/19 09:59 AM
BradH
I also run a Dynamic 9-1/2”. To the OP, I’d send it back to Lupo and explain to them exactly how the engine and car has changed. No one will know that converter better than them. I did speak with Sean once before the last round of engine changes. At that time he mentioned a stator change would be likely, but things have changed even more since then.
