Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709973
10/25/19 11:24 AM
10/25/19 11:24 AM
gregsdart Offline
gregsdart  Offline
Originally Posted by BradH
[quote=calrobb2000]
hi ,
the dynamic worked good for 20 years and you want to know where to get a converter ?
My Dynamic has worked very well so far. My friend's sucked. Nobody hits 100%, and converter tech & good builders can change over 20 years. If the new engine and the old converter aren't a good match, I'd like to know what other people's experiences have been. [/quote
]by your power numbers i would geuss your new combo will want a 7000 to 7200 shift and 6200 stall. As low as 5200 may work well. I would run what you have. I didn't see a lot of change fron 5500 to 6000 stall on my deal. So the problem becomes; if you mess with it you may go backwards. Test the car with the old one and if you want to know if a change is needed buy a new one to compare.
Re: Whose 727 street/strip converters are you using? [Re: Dragula] #2709975
10/25/19 11:25 AM
10/25/19 11:25 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted by Dragula
ATI here......Getting one for a big engine like mine wasn't easy....Love it.
ATI is in Maryland about 60 miles from me, but I've never done any business with them.
Dynamic is in Delaware about 120 miles from me.
If there are other "close" converter companies, I don't know of them. And until what I have now is tested again, this is all "for informational purposes only."
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2709979
10/25/19 11:38 AM
10/25/19 11:38 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
+1 for ATI.
Re: Whose 727 street/strip converters are you using? [Re: gsmopar] #2709999
10/25/19 01:33 PM
10/25/19 01:33 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I have used the ATI treemaster 8" and now a 9.5" - the 8" converter seems to be going the way of the dodo bird pretty quick due to the availability and supply of new cores. The new converter of choice seems to be the 9.5" and is much more durable piece when the HP goes above 800. I also have used a local company called Perfect Converter with some very good results - its nice to be able to drop a converter talk with the owner of the company about it - have them make an adjustment and get it back in a couple of days . A strip/street converter is really a compromise on both ends of the spectrum as you tend to go with a lower stall to accommodate the street behavior. General I have found good results matching the stall with the peak torque of the motor as a base starting point - right now I have the converter at 200 rpm above peak torque and the car really picked up in the sixty - I may try more stall next year. The other side of the equation is efficiency at top end and for me it seems the sweet spot for the converters I use is about 1000 - 1500 above the stall before it becomes less efficient and MPH falls off. Chasing the ideal converter is never ending - I have watched Marco Abruzzi test 5-10 converters in his dragster in a single day in order to find the right one - I am not that ambitious !
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2710183
10/26/19 03:19 PM
10/26/19 03:19 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using a 9.5" PTC that they built for my combination and street / strip . I have no complaints . But, It would be interesting to try a higher stall . work
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Whose 727 street/strip converters are you using? [Re: Hemi Allstate] #2710281
10/26/19 11:44 PM
10/26/19 11:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Luppo Dynamic 9.5 street/strip converter in my 63. And it was not built for the eng in the car as I bought it in 2006 for my old 440 that was about 100 less hp then my 440/493. . But it works fine behind this eng and is still working fine after 13 years of street driving and some drag racing. Ron
Re: Whose 727 street/strip converters are you using? [Re: Hemi Allstate] #2710355
10/27/19 11:52 AM
10/27/19 11:52 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Call PTC and see what they can do.
I sent my 9.5" back to them after 13 years of running it, $150 + shipping to polish the hub and a refresh.
72 Plymouth Roadrunner 11.08@123.25
Re: Whose 727 street/strip converters are you using? [Re: Roughbird72] #2710385
10/27/19 01:58 PM
10/27/19 01:58 PM
gregsdart Offline
gregsdart  Offline
I used an A & A 10 inch medium stall behind my 408 Dart motor. 517 tq at 4600 and it stalled 4,000. There are three stall versions, about 400 rpm apart. Mine was the middle one. It had decent lockup. 2600 rpm at 60mph with 27. Inch tires and 3.55 g e ars.
$700.
Re: Whose 727 street/strip converters are you using? [Re: gregsdart] #2710463
10/27/19 08:42 PM
10/27/19 08:42 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
In my previous posts, I said that I had a 9" that I had originally gotten from PTC. But I see that they actually have it listed as a 9 1/2".
Lenny had told me that I needed a larger converter to get me where I wanted but that meant the elusive 11" core was needed.
Is it possible that the 9", 9 1/2", and 10" converters being mentioned here are in reality based on the same core?
Master, again and still
Re: Whose 727 street/strip converters are you using? [Re: DaveRS23] #2710494
10/27/19 11:02 PM
10/27/19 11:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run a Turbo Action 11" with 7/16 thread flexplate bolt upgrade (I couldn't keep the 5/16 thread bolts to stay tight despite being arp and loctited). 2800 rated stall as I recall.
Surprisingly, it has run a 1.37 60 ft.
'63 Dodge 330
11.19 @ 121 mph
Re: Whose 727 street/strip converters are you using? [Re: GY3] #2710515
10/28/19 12:44 AM
10/28/19 12:44 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Turbo-Action. 17805T if I remember correctly. No complaints.
Re: Whose 727 street/strip converters are you using? [Re: bobby66] #2710517
10/28/19 01:07 AM
10/28/19 01:07 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I also run a Dynamic 9-1/2”. To the OP, I’d send it back to Lupo and explain to them exactly how the engine and car has changed. No one will know that converter better than them.
Re: Whose 727 street/strip converters are you using? [Re: StealthWedge67] #2710541
10/28/19 08:28 AM
10/28/19 08:28 AM
an8sec70cuda Offline
I've used Atlantic Coast Converters for the past 15+ years w/ great results.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Whose 727 street/strip converters are you using? [Re: DaveRS23] #2710554
10/28/19 09:53 AM
10/28/19 09:53 AM
BradH Offline OP
BradH  Offline OP
Not from what I have seen... but I ain't in the converter biz, either.
Re: Whose 727 street/strip converters are you using? [Re: BradH] #2710558
10/28/19 09:58 AM
10/28/19 09:58 AM
If I'm not mistaken, I think the 9" and 9.5" converter are the same. I remember my converter builder mentioning that, but it's been years ago. He's always built 9" converters for my stuff.
Brad...FWIW, my guy really likes ATI and buys a lot of parts from them.
CHIP
Re: Whose 727 street/strip converters are you using? [Re: StealthWedge67] #2710560
10/28/19 09:59 AM
10/28/19 09:59 AM
BradH Offline OP
BradH  Offline OP
I did speak with Sean once before the last round of engine changes. At that time he mentioned a stator change would be likely, but things have changed even more since then.
