Power Brake Booster experts - help #2709261
10/22/19 06:27 PM
10/22/19 06:27 PM
A727Tflite Offline OP
Anyone know if the power brake boosters use the same pushrod between the booster and master ?
I have a 71 Hemi booster and after separating the master from the booster I notice it is knarled up where the front booster seal will ride. Looking for another rod before I have this one welded and ground.
Re: Power Brake Booster experts - help [Re: A727Tflite] #2709336
10/22/19 09:51 PM
10/22/19 09:51 PM
WV
Little Detroit Offline
WV
don't know how bad it is marled up but, If it were me I would look to see if a "speedy sleeve" is available in that size before I would weld it , it may be tempered. and there is no difference in the "tear drop " pushrod coming out of the back of the booster. the difference between b& e body is the flat pushrod that connects to the brake peddle and the booster bell crank linkage.
Re: Power Brake Booster experts - help [Re: Little Detroit] #2709337
10/22/19 09:55 PM
10/22/19 09:55 PM
WV
WV
by the way I can sell you a complete unit master cylinder booster ,linkage and firewall reinforcement all rebuilt by POWER BRAKE EXCHANGE of Pittsburgh Pa. if need a unit .
Re: Power Brake Booster experts - help [Re: Little Detroit] #2709396
10/23/19 07:57 AM
10/23/19 07:57 AM
Thenunit you have for sale will fit a 1971 Hemi GTX?
How much?
Not sure how you would get a speedy sleeve over the nub on the pushrod that enters the master.
Re: Power Brake Booster experts - help [Re: A727Tflite] #2709677
10/23/19 10:03 PM
10/23/19 10:03 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
will be the same as 66-70 dic brake b body cars with bendex duel diaphragm
the ram man has them as well
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Power Brake Booster experts - help [Re: 1969gtx] #2709881
10/24/19 08:57 PM
10/24/19 08:57 PM
VA
dragon slayer Offline
VA
Hemi Bendix booster is different then the Non hemi B Body Bendix booster. There also is a difference in the Hemi 66-67 (maybe up to early 68) and the 68 to 71 Hemi in the size of the vacuum fitting hole. Cosmetic, but if your going for OEM concourse it would matter.
Re: Power Brake Booster experts - help [Re: A727Tflite] #2710160
10/26/19 01:58 PM
10/26/19 01:58 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'd call up Booster Dewey and see if they have a spare lying around before I tried repairing the one you have.
Re: Power Brake Booster experts - help [Re: 6PakBee] #2710234
10/26/19 07:35 PM
10/26/19 07:35 PM
Thanks for all the replies. I’m sending the booster out for repair/restoration and was getting ahead of myself in case a rod is needed.
Re: Power Brake Booster experts - help [Re: 6PakBee] #2711352
10/30/19 06:26 PM
10/30/19 06:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
