E Body front seat back bumpers #2045816
04/03/16 11:43 PM
04/03/16 11:43 PM
3
340clone Offline OP
340clone  Offline OP
Does anyone have a photo of how the nylon seat back bumpers should be installed on 70-71 E Bodies? I have a set, but can't figure out how they fit onto the seat backs.
Thanks!
Re: E Body front seat back bumpers [Re: 340clone] #2045819
04/03/16 11:46 PM
04/03/16 11:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They press onto large screws, do you have those?
Re: E Body front seat back bumpers [Re: 340clone] #2045824
04/03/16 11:58 PM
04/03/16 11:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 & early 1971 seat bumpers, note the two different screw tip styles. (they interchange just fine)
Re: E Body front seat back bumpers [Re: 340clone] #2045829
04/04/16 12:00 AM
04/04/16 12:00 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Where they go after the foam & upholstery is on. (passenger side bucket seat back shown)
Re: E Body front seat back bumpers [Re: Alaskan_TA] #2708461
10/20/19 09:20 AM
10/20/19 09:20 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Digging up an older thread to ask the question . . .
So it appears most seat bumpers did not survive the test of time. Looking at the pic Barry posted it supports another picture I've seen posted by him of a bumper that did manage to survive. Looking at this installation method intuitively doesn't make sense to me, and leaves little doubt why most bumpers broke. This installation forces the bumper to support the occupant loads placed against the seat back, where the fastener is simply holding the bumper in position.
Looking at the engineering drawing it shows the screw being inserted thru the spacer into the seat back. (photo attached). Additionally the instructions provided by note 9 state to insert E (screw) thru hole in item F (bumper) and threading into the seat back. Installation by this method would support why the screw length is as long as it is. Had the intent of engineering been to install as previously suggested by this thread the spacer would have been drawn above the screw and the instructions would have stated to insert item E (screw) into bottom of F (bumper) . . . and the screw could have been much shorter in length.
Doing as instructed by the engineering drawing would make the bumper/spacer intent to eliminate the metal to metal striking of the screw on the seat bottom plate, a spacer for setting the screw depth, and a more appealing close out to a screw being exposed. The screw would then be used to support the forces created by the occupant and would have only a small piece of nylon extending beyond the screw head acting as a spacer and strike guard. In the event the spacer/bumper were to fail the seat back would still be supported by the fastener.
So where all bumpers installed as shown by this thread or was this simply one interpretation by a line worker.
Thanks for the input.
Screen Shot 2019-10-20 at 4.42.24 AM.pngScreen Shot 2019-10-20 at 4.41.42 AM.png
Re: E Body front seat back bumpers [Re: AAR#2] #2708472
10/20/19 09:59 AM
10/20/19 09:59 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Look at the caged seat back release button, that is the late '71 up type.
They typically used a different bumper system with a spring.
I'll get a photo of one when I get out to my shop in a bit.
Edit - this is the late '71 model year & newer type;
Re: E Body front seat back bumpers [Re: Alaskan_TA] #2708631
10/20/19 06:44 PM
10/20/19 06:44 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Maybe I’m missing it Barry, unsure how that helps me with the 70 style and the discrepancy.
Re: E Body front seat back bumpers [Re: AAR#2] #2708634
10/20/19 06:55 PM
10/20/19 06:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The drawing above is for a late 1971 up seat, so it is too new to use for 1970 model year seats / bumpers if that helps?
Re: E Body front seat back bumpers [Re: Alaskan_TA] #2708660
10/20/19 08:56 PM
10/20/19 08:56 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
OK, to your point the drawing was initially released in May of 69 and was revised and redrawn in Aug of 70.
Honestly the image in the drawing of the spacer isn't a good representation of the 70, or later spacer you posted.
The 70 Service manual isn't of any help on the matter either. Same image as the engineering drawing but without find numbers and notes.
Back in the day I suspect I'd have gotten a few survivor pics on this thread but these days this place is a ghost town. Its a real shame
Re: E Body front seat back bumpers [Re: AAR#2] #2708765
10/21/19 08:38 AM
10/21/19 08:38 AM
MD
floyd Offline
floyd  Offline
MD
Here’s an original in my 71 Challenger. It’s an early-build car with several 70-style features. Funny, I replaced the D/S bumper awhile back and didn’t even check the other side to see how it was positioned. Looks like I’ll need to redo it.
Re: E Body front seat back bumpers [Re: floyd] #2708784
10/21/19 09:31 AM
10/21/19 09:31 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Good to see a few folks still on here, and thanks for the photo, that certainly supports what Barry has posted.
Sounds like you too thought the screw should be inserted through the spacer/bumper.
Re: 1970 A, E & B Body front seat back bumpers [Re: AAR#2] #2708889
10/21/19 02:37 PM
10/21/19 02:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Here is an early 1970 model year in black that failed as they typically do with time;
Re: 1970 A, E & B Body front seat back bumpers [Re: Alaskan_TA] #2708892
10/21/19 02:42 PM
10/21/19 02:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Another early version in black on my 1970 Sport Satellite;
Re: 1970 A, E & B Body front seat back bumpers [Re: Alaskan_TA] #2708899
10/21/19 03:00 PM
10/21/19 03:00 PM
MD
floyd Offline
floyd  Offline
MD
Just found this in my stash. Removed from a 70 Challenger.
Re: 1970 A, E & B Body front seat back bumpers [Re: floyd] #2708906
10/21/19 03:31 PM
10/21/19 03:31 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Thanks guys, I don’t have to like the design, nor understand the rational, looks like I have my direction.
Thanks for the help
Re: 1970 A, E & B Body front seat back bumpers [Re: AAR#2] #2709198
10/22/19 01:45 PM
10/22/19 01:45 PM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
Thanks for the help
You chose wisely Grasshopper..............................
Always best to confirm what's correct or factory even if it takes two weeks.............
Great info here.................
