Re: Brett miller and the mw victor project
[Re: BradH]
#2708595
10/20/19 04:35 PM
10/20/19 04:35 PM
Posts: 9,113 Rogue River, OR
Jeremiah
Rogue River, OR
I think a lot of this talk would be put to bed if a few of us could get our cars finished. My victor mw engine is cammed to make power from about 5000-7500 n/a. It was spec'd for my stick car with a little spray. It dyno'd 686hp first pull, 751 last pull n/a. Car is a four speed with pretty close ratios on a 10.5x29.5. SLR is 11.5. Before it ever leaves the barn it will have DA shocks and DAQ. I don't have time to shoot in the dark. The combo is not practical to most people because the trend in drag racing is to have 3200hp and two speeds. I have no interest in that and have a distaste for ratchet shifters. So lets take my high winding 511 and dump it in a car with a 10" street/strip converter and a pg. Major disappointments on the horizon lol. Now maybe put it in something light with a big tire a loose 5500 stall converter and 5.13s you will have better results. Even if you have a three speed auto with a tight converter my engine would probably be a dog. It needs rear gear and to stay upstairs in the power band. If i wanted to knock the tires off at 1500rpm i drive the 6.7 cummins!
My point is the whole car needs to work. If the engine is not doing what is expected in the car on a chassis dyno or race track i would be yanking it and off to a known/competent dyno operator ala PRH or Best. .
[Re: Jeremiah]
#2708598
10/20/19 04:42 PM
10/20/19 04:42 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wonder which B1 heads these were....... originals? B1BS?
[Re: BradH]
#2708618
10/20/19 05:38 PM
10/20/19 05:38 PM
fast68plymouth
So. Burlington, Vt.
A pic of the motor with a clear view of the intake manifold would tell the tale most likely.
I don’t really need to know...... more curious than anything.
[Re: Jeremiah]
#2708641
10/20/19 07:54 PM
10/20/19 07:54 PM
Posts: 8,077 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I think Jeremiah and Rob have the most answers to how to make these heads really work. I read thru some of their old posts as well.
[Re: fast68plymouth]
#2708653
10/20/19 08:39 PM
10/20/19 08:39 PM
Posts: 1,057 The Great White North
RAMM
I'm 90% sure they were originals. BTW Scott Koffel is an awesome dude. We had A LOT of fun that year. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: BradH]
#2708654
10/20/19 08:42 PM
10/20/19 08:42 PM
RAMM
Hey they outscored us by 24 points! J.Rob
#2708655
10/20/19 08:45 PM
10/20/19 08:45 PM
RAMM
BES numbers.......
Not that it really means anything, but the picture they show for this head, which looks like it’s right out of the Ede catalog, is of a std port 1st gen head. At 335cc....... it would likely be a MW Head. This flow curve is actually pretty accurate and I've used the Victors enough to know where and why they lack. The .400" lift number is something else on these , it is usually 265 ish which is terrible. J.Rob
#2708656
10/20/19 08:48 PM
10/20/19 08:48 PM
RAMM
I have been told that Victors flowing 400 cfm posess a 4" square C.S.A. which kinda tells you almost everything you need to know. J.Rob
[Re: BradH]
#2708658
10/20/19 08:53 PM
10/20/19 08:53 PM
RAMM
Huh...... were the rules weird for that class that year? Let's ask Jesse, since he had entered a 354 Gen IIII Hemi in the same class. The rules can probably be found Googling EngineMAsters Challenge 2018/JE Pistons or something like that. I wouldn't say they were weird but then again they have to keep it fresh. J.Rob
[Re: RAMM]
#2708662
10/20/19 09:03 PM
10/20/19 09:03 PM
fast68plymouth
So. Burlington, Vt.
Brads std port Victors were in the 275@.400 range, with the finished ports right around 300cc iirc(I wanna say 297cc??).
An ootb std port 2nd gen Victor is 249@.400.
[Re: mopar dave]
#2708688
10/20/19 10:15 PM
10/20/19 10:15 PM
fast68plymouth
So. Burlington, Vt.
Here an example of why looking at any one aspect of a set of heads doesn’t even begin to tell you how they’ll work.
I freshened a set of Indy 572-13’s last year. They came off a motor built by a very well known big name Mopar builder. Cnc ported, 2.350 intake valve....... they’re used on a high CR 588 making over 1000hp. Flow@.400?? 250.
[Re: mopar dave]
#2708692
10/20/19 10:25 PM
10/20/19 10:25 PM
BradH
My last data points, then I'll back away from the keyboard and let the discussion continue without me.
Avg of 4 intake port tests on PRH flow bench with 2.20" valve: .100 - 75 .200 - 151 .300 - 220 .400 - 280 .500 - 326 .600 - 346 .700 - 355
294 cc; Min CSA 2.65; Avg CSA 2.76
This is a true standard port opening that requires no gasket trimming for proper port alignment.
EDIT (and THEN I'll go away): To anyone outside of the Mopar world, those specs would pass for a mediocre -- at best -- 15* SB Chevy head. I've joked around before that building a stock-stroke 440 is basically building a stroker small-block with a really sh!tty bob weight.
[Re: BradH]
#2708713
10/20/19 11:25 PM
10/20/19 11:25 PM
mopar dave
Mt Morris Michigan
My mistake, mine is 3.61. Time to go to bed. Yours flow better than mine and are smaller making a much better head .
