Page 2 of 3 1 2 3
Re: Brett miller and the mw victor project [Re: BradH] #2708595
10/20/19 03:35 PM
10/20/19 03:35 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I think a lot of this talk would be put to bed if a few of us could get our cars finished. My victor mw engine is cammed to make power from about 5000-7500 n/a. It was spec'd for my stick car with a little spray. It dyno'd 686hp first pull, 751 last pull n/a. Car is a four speed with pretty close ratios on a 10.5x29.5. SLR is 11.5. Before it ever leaves the barn it will have DA shocks and DAQ. I don't have time to shoot in the dark. The combo is not practical to most people because the trend in drag racing is to have 3200hp and two speeds. I have no interest in that and have a distaste for ratchet shifters. So lets take my high winding 511 and dump it in a car with a 10" street/strip converter and a pg. Major disappointments on the horizon lol. Now maybe put it in something light with a big tire a loose 5500 stall converter and 5.13s you will have better results. Even if you have a three speed auto with a tight converter my engine would probably be a dog. It needs rear gear and to stay upstairs in the power band. If i wanted to knock the tires off at 1500rpm i drive the 6.7 cummins!
My point is the whole car needs to work. If the engine is not doing what is expected in the car on a chassis dyno or race track i would be yanking it and off to a known/competent dyno operator ala PRH or Best. .
Re: Brett miller and the mw victor project [Re: Jeremiah] #2708598
10/20/19 03:42 PM
10/20/19 03:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I wonder which B1 heads these were....... originals? B1BS?
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708614
10/20/19 04:28 PM
10/20/19 04:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
No idea; what info I have is what I posted. Don't know if C Speier has any info on his FB page from that time.
Re: Brett miller and the mw victor project [Re: BradH] #2708618
10/20/19 04:38 PM
10/20/19 04:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
A pic of the motor with a clear view of the intake manifold would tell the tale most likely.
I don’t really need to know...... more curious than anything.
Re: Brett miller and the mw victor project [Re: BradH] #2708637
10/20/19 06:42 PM
10/20/19 06:42 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Nothing happened to it and I may do just that. I don't follow everyone's lead like a sheep. I get a bunch of opinions and as much data as I can find. Then I attempt a project with all the info I sorted thru and come up with a plan and hopefully the right direction. Most of the time it saves money and time. There is always a method to my madness. Thanks
Re: Brett miller and the mw victor project [Re: Jeremiah] #2708641
10/20/19 06:54 PM
10/20/19 06:54 PM
Mt Morris Michigan
Mt Morris Michigan
I think Jeremiah and Rob have the most answers to how to make these heads really work. I read thru some of their old posts as well.
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708642
10/20/19 06:55 PM
10/20/19 06:55 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, this is the old post I was referring to.
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708653
10/20/19 07:39 PM
10/20/19 07:39 PM
The Great White North
RAMM Offline
RAMM  Offline
I'm 90% sure they were originals. BTW Scott Koffel is an awesome dude. We had A LOT of fun that year. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Brett miller and the mw victor project [Re: BradH] #2708654
10/20/19 07:42 PM
10/20/19 07:42 PM
RAMM Offline
RAMM  Offline
Originally Posted by BradH
Pooch #2
Hey they outscored us by 24 points! J.Rob
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708655
10/20/19 07:45 PM
10/20/19 07:45 PM
RAMM Offline
RAMM  Offline
Originally Posted by fast68plymouth
BES numbers.......
Not that it really means anything, but the picture they show for this head, which looks like it’s right out of the Ede catalog, is of a std port 1st gen head.
At 335cc....... it would likely be a MW Head.
This flow curve is actually pretty accurate and I've used the Victors enough to know where and why they lack. The .400" lift number is something else on these , it is usually 265 ish which is terrible. J.Rob
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708656
10/20/19 07:48 PM
10/20/19 07:48 PM
RAMM Offline
RAMM  Offline
https://board.moparts.org/ubbthread...-bb-victor-heads-update.html#Post2281884
I wonder if he ever CC’d that port?
SRH used to have the flow data for his CNC job on the website, but I couldn’t find it today.
I have been told that Victors flowing 400 cfm posess a 4" square C.S.A. which kinda tells you almost everything you need to know. J.Rob
Re: Brett miller and the mw victor project [Re: BradH] #2708658
10/20/19 07:53 PM
10/20/19 07:53 PM
RAMM Offline
RAMM  Offline
Huh...... were the rules weird for that class that year?
Let's ask Jesse, since he had entered a 354 Gen IIII Hemi in the same class. shruggy
The rules can probably be found Googling EngineMAsters Challenge 2018/JE Pistons or something like that. I wouldn't say they were weird but then again they have to keep it fresh. J.Rob
Re: Brett miller and the mw victor project [Re: RAMM] #2708662
10/20/19 08:03 PM
10/20/19 08:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
Brads std port Victors were in the 275@.400 range, with the finished ports right around 300cc iirc(I wanna say 297cc??).
An ootb std port 2nd gen Victor is 249@.400.
Re: Brett miller and the mw victor project [Re: fast68plymouth] #2708674
10/20/19 08:52 PM
10/20/19 08:52 PM
Mt Morris Michigan
Mt Morris Michigan
Brad's heads are as good as mine, maybe better. I have 278.6@.400
Re: Brett miller and the mw victor project [Re: RAMM] #2708677
10/20/19 08:58 PM
10/20/19 08:58 PM
Mt Morris Michigan
Mt Morris Michigan
That's huge. My csa is 2.625x1.375 =3.61 at the gasket.
Re: Brett miller and the mw victor project [Re: mopar dave] #2708688
10/20/19 09:15 PM
10/20/19 09:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Here an example of why looking at any one aspect of a set of heads doesn’t even begin to tell you how they’ll work.
I freshened a set of Indy 572-13’s last year. They came off a motor built by a very well known big name Mopar builder.
Cnc ported, 2.350 intake valve....... they’re used on a high CR 588 making over 1000hp.
Flow@.400?? 250.
Re: Brett miller and the mw victor project [Re: mopar dave] #2708692
10/20/19 09:25 PM
10/20/19 09:25 PM
BradH Offline
BradH  Offline
My last data points, then I'll back away from the keyboard and let the discussion continue without me.
Avg of 4 intake port tests on PRH flow bench with 2.20" valve:
.100 - 75
.200 - 151
.300 - 220
.400 - 280
.500 - 326
.600 - 346
.700 - 355
294 cc; Min CSA 2.65; Avg CSA 2.76
This is a true standard port opening that requires no gasket trimming for proper port alignment.
EDIT (and THEN I'll go away): To anyone outside of the Mopar world, those specs would pass for a mediocre -- at best -- 15* SB Chevy head. I've joked around before that building a stock-stroke 440 is basically building a stroker small-block with a really sh!tty bob weight.
Re: Brett miller and the mw victor project [Re: BradH] #2708709
10/20/19 10:18 PM
10/20/19 10:18 PM
Mt Morris Michigan
Mt Morris Michigan
LOL! I really agree with the last part. My heads are very similar to yours, But your CSA is larger. Not sure why, but mine cc at 330cc.
Re: Brett miller and the mw victor project [Re: mopar dave] #2708710
10/20/19 10:20 PM
10/20/19 10:20 PM
BradH Offline
BradH  Offline
Re: Brett miller and the mw victor project [Re: BradH] #2708713
10/20/19 10:25 PM
10/20/19 10:25 PM
Mt Morris Michigan
Mt Morris Michigan
My mistake, mine is 3.61. Time to go to bed. Yours flow better than mine and are smaller making a much better head .
Page 2 of 3 1 2 3
