Re: Brett miller and the mw victor project
[Re: 340Cuda]
#2708514
10/20/19 12:00 PM
10/20/19 12:00 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
is that the engine in shiloh davies's dart ?
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2708518
10/20/19 12:11 PM
10/20/19 12:11 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
is that the engine in shiloh davies's dart ? No, Shiloh's is a early Ritter block with W8 heads
"Just a Bracket car dressed up like a streetcar"
[Re: mopar dave]
#2708527
10/20/19 12:34 PM
10/20/19 12:34 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
Small block not big block
[Re: mopar dave]
#2708529
10/20/19 12:41 PM
10/20/19 12:41 PM
BradH
Yes, Brett took a crack at a BB MW Victor. As I recall, he did one port and decided it wasn't worth pursuing further. (EDIT: This is my a$$umption, but Brett could provide more details if he happens to see this thread). The numbers looked good, but weren't much different than what Chad Speier advertised for his CNC MW Victor program.
In general, the MW Victors CNC programs I've seen advertised (Speier, BES, Modern) all end up with big runner volumes for the sake of getting big flow #s at .700-.900" lift. Below that, I don't recall them being any better -- some not even as good -- as my PRH-ported standard Victors. IMO, those heads are ALL going to exhibit the same thing you're experiencing now with the Hughes heads, if you don't tailor the rest of the combination to work with them.
Somebody had an EMC (2017 or 2018?) entry with the BES heads that was IMO a big underperformer. When I read the details of the build and saw the heads that were used, it was a no-brainer to me why.
Dave - What happened to replicating what worked when YOUR heads ran 9s? You're getting so wrapped around the axle over this it's painful to read each new thread you start.
[Re: BradH]
#2708547
10/20/19 02:10 PM
10/20/19 02:10 PM
fast68plymouth
So. Burlington, Vt.
Apparently I don’t know the secret password for searching for any year Engine Masters final results/standings/order.
Got a link to the specifics on that Victor headed build?
Also, I may not be remembering it right, but....... I thought Brett started with a std port head....... and the port configuration he came up with was something that would have also required a heavily modified/custom intake manifold. He did not end up with a traditional MW type of port opening.
[Re: fast68plymouth]
#2708548
10/20/19 02:12 PM
10/20/19 02:12 PM
Posts: 1,051 The Great White North
RAMM
It was bright green and it did underperform. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#2708552
10/20/19 02:24 PM
10/20/19 02:24 PM
fast68plymouth
So. Burlington, Vt.
BES numbers.......
Not that it really means anything, but the picture they show for this head, which looks like it’s right out of the Ede catalog, is of a std port 1st gen head. At 335cc....... it would likely be a MW Head.
[Re: BradH]
#2708555
10/20/19 02:28 PM
10/20/19 02:28 PM
fast68plymouth
So. Burlington, Vt.
Huh...... were the rules weird for that class that year?
[Re: BradH]
#2708556
10/20/19 02:29 PM
10/20/19 02:29 PM
BradH
Maybe since I have never entered one of those engine competitions I should just keep my mouth shut... but IMO the two RB 452 collaborations that Dwayne and I have worked together on over the years have done better with less.
EDIT: As I mentioned below, I don't know how these scores are calculated; maybe my junk wouldn't place well in an event like this. But the HP & torque for the builds above still look like underachievers to me.
[Re: BradH]
#2708562
10/20/19 02:35 PM
10/20/19 02:35 PM
fast68plymouth
So. Burlington, Vt.
I see the one entry is listed as using a roller cam....... so it’s not flat tappet only. Maybe a low-ish CR rule?
4150 carb only?
Small header collectors?
Low-ish operating range?
#2708563
10/20/19 02:35 PM
10/20/19 02:35 PM
BradH
I don't remember what he started with, but the end result was, as you stated, not a "traditional MW type of port opening."
#2708566
10/20/19 02:40 PM
10/20/19 02:40 PM
BradH
4150 carb only?
Low-ish operating range? Top 3 in the class: EDIT: Notes for 1st place say 11.3 CR and 4th place say 11.7 CR... And I have NO idea how they score these things.
