Re: Guess E.T change going from 4.88 to 4.30 gears
[Re: Supersonic]
#270842
04/05/09 05:58 PM
04/05/09 05:58 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
The car spun badly the first 2 time runs, my first elimination run it went a 1.45 60', 6.61 at 103 in the 1/8th, i had the mustang beat badly so i let off and go on the brakes hard and went through at 10.49 @ 114. Hopefully in some really good air it will get into the high 20's. My best 60' with the 4.88's was 1.44, the car go's through at about 6500 now.
Your 60's will drop more with better hook. I was hoping to see more MPH but you did hit the brakes, still your only .01 off your best 60 with the 4.88's...not bad for first time out. ..Phill
[Re: 9 Sec Phill]
#270843
04/05/09 06:02 PM
04/05/09 06:02 PM
Posts: 51 Cumberland, MD
Supersonic
Cumberland, MD
It went through at 128 my fist time run, but it spun almost sideways off the line, my 60' was1.52 and it only ran a 10.54 that run. I think it will be over 130 mph with a good full pass
[Re: 9 Sec Phill]
#270845
04/05/09 06:11 PM
04/05/09 06:11 PM
Supersonic
Cumberland, MD
You might enen want to try a higher gear still, some 3.91's...you might be suprised at the out come. ...Phill
Yea, with these iron heads i know i need to keep the motor around the 5600-5900 range as long as possible. I wish gears didn't cost so much money, i'd try a set.
[Re: B1MAXX]
#270847
04/06/09 01:31 PM
04/06/09 01:31 PM
Supersonic
Cumberland, MD
Continue to keep us posted. Let us know when it does go quicker than the 4:88's
Sounds good, i probably won't make it back down for a few weeks.
[Re: B1MAXX]
#270848
11/02/09 08:53 PM
11/02/09 08:53 PM
Supersonic
Cumberland, MD
Was at the track sunday, the car ran 10.23 @ 129 with the 4.30's and nothing else done to the motor. Air was decent
[Re: B1MAXX]
#270850
11/03/09 01:49 PM
11/03/09 01:49 PM
Posts: 6,295 U.S.
moparniac
U.S.
If he was nosing over through the gears from too high of rpm wouldnt the 4.30's be better shifting lower rpm..... what rpm did you shift at with the 4.30's ?
Mopar Performance
[Re: Supersonic]
#270851
11/03/09 05:31 PM
11/03/09 05:31 PM
Posts: 16,931 NC
440Jim
NC
7200 running a 10.38 @ 127 with 4.88's
That is a good gain. What was the sixty foot comparison? Was the weather similar on both runs?
[Re: 440Jim]
#270852
11/03/09 10:08 PM
11/03/09 10:08 PM
Supersonic
Cumberland, MD
yes, the weather was close on both of those runs. Best 60' with the 4.88 gears was a 1.46, and best with the 4.30's was a 1.42. I am running a crane cam with 700 lift. Shifting the car at 6000 now and it goes through the traps around 6500.
[Re: 340man4ever]
#270853
11/03/09 10:20 PM
11/03/09 10:20 PM
Posts: 216 still waiting on 684
Kiner
Supersonic- i'd be interested to know the race weight of your car and the cam/compression combo
Me too.Would like to know.
[Re: Supersonic]
#270854
11/03/09 10:48 PM
11/03/09 10:48 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
What Intake and Carb do you have? What does your car weigh?
We have a similar combo with similar numbers
