Re: Which Flexplate?? 360/904
[Re: wkroncke17]
#2708242
10/19/19 02:26 AM
10/19/19 02:26 AM
Posts: 43,172 Bend,OR USA
Cab_Burge
Mopar made only 2 flex plates for the stock 904 tranny cars that I have heard of or seen, that being said they where 11.0 inch converters with 5/16 converter bolts the smaller 10.0 with 5/16 bolts. On your deal your probably going to need a Hi Po 727 6 bolt crank pattern for either the 11.0 inch pattern with the 7/16 bolts or the other one for 10.0 inch pattern with the 7/16 converter bolts. B&M use to offer a solid universal 6 bolt flex plate with all four patterns on them, not sure if they still do and how good they are now Good luck, Mopar offers the Hi Po 6 and 8 bolt Hi Po flex plate for internally balanced motors only with the single pattern for the race converters with the 7/16 converter bolt sizes in both SFI specs and non SFI specs The converter size determines which flex plate you will need, not the tranny case
[Re: Cab_Burge]
#2708286
10/19/19 10:24 AM
10/19/19 10:24 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Mopar made only 2 flex plates for the stock 904 tranny cars that I have heard of or seen, that being said they where 11.0 inch converters with 5/16 converter bolts the smaller 10.0 with 5/16 bolts. On your deal your probably going to need a Hi Po 727 6 bolt crank pattern for either the 11.0 inch pattern with the 7/16 bolts or the other one for 10.0 inch pattern with the 7/16 converter bolts. B&M use to offer a solid universal 6 bolt flex plate with all four patterns on them, not sure if they still do and how good they are now Good luck, Mopar offers the Hi Po 6 and 8 bolt Hi Po flex plate for internally balanced motors only with the single pattern for the race converters with the 7/16 converter bolt sizes in both SFI specs and non SFI specs The converter size determines which flex plate you will need, not the tranny case Cab, thank you so much for the very detailed explanation. I drag raced this car 30 years ago. Used a B&M Super Holeshot converter with a 727 and standard externally balanced 360. Parts were specific for it from what I remember. Thank goodness technology has come a long way but this is one conundrum I couldn’t find a part “specific” for. It looks as if the one the J Body posted below (Thanks J Body!) will be the one to use. It’s the B&M #10230. It is listed as Mopar V8 6 Bolt internet balance engine for 727. So I’m assuming it will work with either Big or small block as long as it’s internally balanced? And.....I assume it will work with a 727 or 904? And it has the dual bolt pattern. Thanks again guys. Very helpful. Wally.
[Re: wkroncke17]
#2708302
10/19/19 11:11 AM
10/19/19 11:11 AM
Posts: 19,402 north of coder
moparx
if it's for an internal balance engine, it should work, as i "think" the bolt pattern of the cranks are the same. [there i go "thinking" again. ] if i'm wrong, can someone correct me, please ?
[Re: wkroncke17]
#2708319
10/19/19 12:28 PM
10/19/19 12:28 PM
RapidRobert
Building a 360w/stroker crank which will be internally balanced and running a 904 transmission. Any OE 904 flexplate will work for you & you will be running an internally balanced torque converter.
[Re: RapidRobert]
#2708324
10/19/19 12:55 PM
10/19/19 12:55 PM
wkroncke17
Wisconsin
Building a 360w/stroker crank which will be internally balanced and running a 904 transmission. Any OE 904 flexplate will work for you & you will be running an internally balanced torque converter. I will be drag racing the car (Mid 11’s) Should I get an SFI approved one?
[Re: wkroncke17]
#2708326
10/19/19 01:02 PM
10/19/19 01:02 PM
RapidRobert
I ain't a drag racer but Cab & others are & will answer. I would assume that it is required or a good safety mode (or both).
[Re: wkroncke17]
#2708330
10/19/19 01:12 PM
10/19/19 01:12 PM
Cab_Burge
I will be drag racing the car (Mid 11’s) Should I get an SFI approved one? [/quote] Buy the converter first unless you only want the B&M plate If so on the SFI certs. it not required for your deal and you already know the price differences, the only difference between the plates is the decal
[Re: Cab_Burge]
#2708352
10/19/19 03:47 PM
10/19/19 03:47 PM
wkroncke17
Wisconsin
Buy the converter first unless you only want the B&M plate If so on the SFI certs. it not required for your deal and you already know the price differences, the only difference between the plates is the decal [/quote] Are you serious?. Why have the rating at all then? That’s crazy but I suppose if it’s mandatory I’ll spend the few extra $$ and just get it. So to be 100% correct, the B&M 10230 will work? I’m not to the Cam/converter yet, I’m getting this and the balancer so my engine builder can balance the rotating assembly. Thank you again Cab!
[Re: wkroncke17]
#2708404
10/19/19 08:02 PM
10/19/19 08:02 PM
Cab_Burge
I've used a bunch of stock Mopar Hi Po 727 solid ( with no stamped opening spaces between the ears) flex plates both 6 bolt and 8 bolt,(non certified and SFI certified) on SB,BB and hemi motors with stock 11 converters all the way down to custom built 8 inch drag race converters with no issues so far I know of other racers that had issues with the stock flex plates and they had the same issues with a after market SFI flex plate that had actual mechanical issues in their cars that caused the breakage to start with, the SFI stickers didn't fix it is my message I have both types and part number Mopar Hi Po flex plates on my shelfs, the only noticeable differences between them is the decal and price
[Re: Cab_Burge]
#2711982
11/01/19 09:45 PM
11/01/19 09:45 PM
wkroncke17
Wisconsin
I called B&M just to be 100% sure. Part # 10230 is listed on their site for Mopar V8 internal balanced for 727. They confirmed it is for Big or Small block, with a 727 or 904 transmission. So, that is the one I need specifically from B&M. Now, as I was searching other websites, (440 source to be exact) they list one for Mopar V8, internal balance for a 727. I called them, confirmed that is is universal for small/big block and for 727/904. More importantly it’s $39 (SFI approved) .The B&M piece is $112. I think I found my flex plate!
Wally.
[Re: J_BODY]
#2712040
11/02/19 09:30 AM
11/02/19 09:30 AM
wkroncke17
Wisconsin
Crackedbacks comment has me thinking I “might” have had to clearance a bit.... I ran into a couple issues with my 904 install (One for sure because of the R3 block). Be sure to check! I think I’ll start a new thread to find out all that I can to be 100% sure, just like the flex plate.
