WHAT STARTER ?
#2707958
10/18/19 09:36 AM
10/18/19 09:36 AM
Posts: 4,699 On the parachute mount
n20mstr
Ive seen these threads before...BUT I have a Mopar Mini already. WHat I have is a 13.7 comp and a 12v battery. Now its starting to kick back, backfire etc. Not good. Im making the switch to a litium 16v. Next step is a better starter ? WHat brand ?
....BAD A$$ STREET CAR.....
Re: WHAT STARTER ?
[Re: n20mstr]
#2707962
10/18/19 09:42 AM
10/18/19 09:42 AM
Posts: 34,953 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Change to a 16 v ..
Or, I run two big 12 volt batteries from Napa .. the really big ones
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: WHAT STARTER ?
[Re: bigdad]
#2708035
10/18/19 12:04 PM
10/18/19 12:04 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I have a Powermaster on the Stratus with a 16V Lithium Pros battery and no issues and this engine is fairly difficult to turn over by hand as it has 60MM Babbit gearings and a fair amount of spring. The dragster has an XS 16V with a Mopar mini starter with zero issues, I did purchase a Powermaster for it as well but so far zero issues with the Mopar mini
Re: WHAT STARTER ?
[Re: n20mstr]
#2708038
10/18/19 12:09 PM
10/18/19 12:09 PM
Posts: 4,457 Washington
madscientist
Washington
Ive seen these threads before...BUT I have a Mopar Mini already. WHat I have is a 13.7 comp and a 12v battery. Now its starting to kick back, backfire etc. Not good. Im making the switch to a litium 16v. Next step is a better starter ? WHat brand ? If you are already running two 12 volt batteries skip the 16 volt deal. Buy a series parallel switch and run the starter off 24 volts. With that switch, only the starter gets 24 volts and everything else always gets 12 volts. Much better way to do it than going to 16 volt stuff.
Re: WHAT STARTER ?
[Re: madscientist]
#2708041
10/18/19 12:29 PM
10/18/19 12:29 PM
Al_Alguire
Las Vegas
My Lithium battery weighs just over 9lbs, the XS in the dragster weighs 30lbs. Both way better options that 90 plus pounds of battery in the car..
Re: WHAT STARTER ?
[Re: n20mstr]
#2708044
10/18/19 12:35 PM
10/18/19 12:35 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
WHat I have is a 13.7 comp and a 12v battery. Now its starting to kick back, backfire etc. Tuneup? Have you tried killing the ignition until the starter gets up to speed?
Re: WHAT STARTER ?
[Re: John_Kunkel]
#2708049
10/18/19 12:42 PM
10/18/19 12:42 PM
n20mstr
WHat I have is a 13.7 comp and a 12v battery. Now its starting to kick back, backfire etc. Tuneup? Have you tried killing the ignition until the starter gets up to speed? YES, still turns over slow. The battery is almost three years old. And its only one group 24 12volt
Re: WHAT STARTER ?
[Re: n20mstr]
#2708056
10/18/19 12:50 PM
10/18/19 12:50 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man you guys have lots of starter issues.
Re: WHAT STARTER ?
[Re: pittsburghracer]
#2708079
10/18/19 12:58 PM
10/18/19 12:58 PM
n20mstr
Man you guys have lots of starter issues. it starts ok, just looking to get rid of the occasional kickback. And im switching to 16V anyway...so that may actually be it. THis 12v is getting old and im sure the alternator I use is not covering the amp draw.
Re: WHAT STARTER ?
[Re: n20mstr]
#2708114
10/18/19 02:46 PM
10/18/19 02:46 PM
Posts: 2,937 A shed in England
Tig
A shed in England
I ran a supplementary -ve cable from the batteries to the starter, wow what a difference.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: WHAT STARTER ?
[Re: dvw]
#2708148
10/18/19 04:41 PM
10/18/19 04:41 PM
n20mstr
I run the Mopar mini at 15-1. Cold; If you pump the throttle a few times and let it set 30 seconds, one more pump and it fires in one revolution. Hot; one pump 10-15 seconds, same result. Waiting is key. Doug ITS FUNNY you mention that. I have a digital water temp gauge. Ive been doing two pumps under 90*, one pump over 90*. Never waited. And yea I think I need more fuel in the engine because a kick back is really just a lean pop ?
Re: WHAT STARTER ?
[Re: Cab_Burge]
#2708228
10/18/19 11:22 PM
10/18/19 11:22 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
My slow start is not the battery or starter solonoid. I will replace my 10 year old mopar mini with another. 9:1 static CR.
Re: WHAT STARTER ?
[Re: n20mstr]
#2708320
10/19/19 12:34 PM
10/19/19 12:34 PM
RapidRobert
On the stock car it would get cranky when hot. I started cranking it THEN switching on the ign while cranking & that took care of it. Ground your coil wire & try it & see if that takes care of it
Re: WHAT STARTER ?
[Re: n20mstr]
#2708465
10/20/19 09:43 AM
10/20/19 09:43 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Be sure to run an equal size grounding cable to match your 12V+ cable in every location, especially from battery to starter, to ignition and to both heads. Also, as mentioned a few times above, using an ignition 12v+ cut-off switch to allow the motor to start cranking at full speed before flipping the switch to light it works nicely.
As to your posted question, I have an MSD starter in one of my vehicles. It turned out to be overkill, because once I updated my grounds, even an old junkyard starter cranked my stuff over really well.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: WHAT STARTER ?
[Re: Sammy]
#2708706
10/20/19 11:03 PM
10/20/19 11:03 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I run a RobbMC starter , I cranks the 572 Hemi with no problem. What I have found is that a lot of guys use the body/frame as a ground . I did years ago and had slow cranking like the batteries were not up to the task. I ran a #2 cable from the trunk mounted battery ground post to the starter/ bell housing bolt. What a difference it made, engine cranked over like a new car.
