NEW BEST Mopars at the valley Junkyard 360 magnum #2706687
10/14/19 12:51 PM
10/14/19 12:51 PM
On the parachute mount
N
n20mstr Online content OP
n20mstr  Online Content OP
N
Car has no roll bar, Has been running 11.20's last couple times out on motor.
They told my son at tech, Don't go faster than 11.50
1st pass off the trailer it goes 11.185 on the brakes LOL
guess its time for a roll bar, because he wants to start using the plate again ! LOL
....BAD A$$ STREET CAR.....
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2706694
10/14/19 12:58 PM
10/14/19 12:58 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Nice ,, roll bars are good for safety but adding extra lbs stinks.
6.50 @105.26
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: Kindafast] #2706722
10/14/19 02:22 PM
10/14/19 02:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I am assuming junkyard short block with heads, cam , and intake? Magnum or LA?
Doug
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: dvw] #2706723
10/14/19 02:32 PM
10/14/19 02:32 PM
N
N
Doug
was a complete junkyard engine with an intake and a cam. was going 12 teens on motor, best of 10.90 on a plate
Ball honed it, put a standard bore flattop in it. Edelbrock heads, and a slightly bigger cam.
Still a street driven everywhere car, pump gas,
Went 7.03 three times in the 1/8 so im assuming it will go 10.9x on motor now
The air was great also, 270' and only 38 water grains
It has been running 11.20s in the summer
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2706848
10/14/19 10:14 PM
10/14/19 10:14 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
More people need to know about this 360 Magnum.
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: Kindafast] #2707094
10/15/19 08:01 PM
10/15/19 08:01 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
They also stiffen up the chassis to allow for the quick elapsed times.
So in my opinion it’s good weight.
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: actionange] #2707188
10/16/19 08:30 AM
10/16/19 08:30 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Agreed , it will stiffen the car and help with ET sometimes but they are still heavy. And a PITA to get around when you are old like me. LOL
6.50 @105.26
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2707191
10/16/19 08:38 AM
10/16/19 08:38 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted by n20mstr
[Went 7.03 three times in the 1/8 so im assuming it will go 10.9x on motor now
Not sure it's an apples-to-apples comparison, but my junk was stuck in the 11.0s when it ran 7.0s in the 1/8th; had to start dipping into the 6.9s to squeak out a best of 10.97 w/ that build.
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: Kindafast] #2707339
10/16/19 06:37 PM
10/16/19 06:37 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I’m OLD as well but consider climbing over my non swing out roll cage side bar EXERCISE! 🤪👍
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: actionange] #2707348
10/16/19 07:01 PM
10/16/19 07:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Well you would get a kick out of seeing my fat, smelly, old azz climbing in and out of my drivers side window every time I pull my car in and out of my enclosed trailer.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: pittsburghracer] #2707404
10/16/19 09:22 PM
10/16/19 09:22 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Dang I can't get that picture out of my mind now LOL
6.50 @105.26
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: Kindafast] #2707412
10/16/19 09:51 PM
10/16/19 09:51 PM
PA.
"Little"John
"Little"John
PA.
Now to add to the story I have been known to wear short shorts in our sweaty ball Pa summer weather. 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: pittsburghracer] #2707452
10/17/19 12:43 AM
10/17/19 12:43 AM
Sounds like it is time for a good electric winch in your enclosed car trailer work twocents
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2707524
10/17/19 09:16 AM
10/17/19 09:16 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice!!!...care to give details of the build? weight?
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: HardcoreB] #2707579
10/17/19 10:49 AM
10/17/19 10:49 AM
N
N
JUNKYARD magnum 360.
ballhone, flattop forged piston standard bore, zero deck , rings gapped LOOSE .035 , because we like to SPRAY
Stock recon rods, replaced rod bolts
ATI damper (Got to have one good piece keeping the stock crank and rods in there..LOL )
Comp Cam ( I don't know the specs, cam card at home)
Ported Edelbrock heads
RPM air gap intake
Brawler carb, I think its an 850
Small headers I had laying around from the late 70's 3.5" exhaust to some stubby race mufflers with an X pipe
PTC 9.5" converter, stock rebuilt 904 , low first gear 2.76 ( NO man valve body)
Ford explorer 8.8 rear with stock 4.10 gears, ford motorsport posi unit, stock axles
im pretty sure it weighs 3200 with him in it
Its not my car, so that why some stuff im not 100% on...LOL
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2707637
10/17/19 12:51 PM
10/17/19 12:51 PM
BradH Offline
BradH  Offline
What does it 60-ft, and what MPH did it make in the 1/8th on those 7.0 passes?
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: BradH] #2707646
10/17/19 01:06 PM
10/17/19 01:06 PM
N
N
NOT SURE ON THE MPH, BUT IT PRINTS TIMESLIPS CONSITSTENT LOL
1.54 , 7.03 EVERY PASS 3 TIMES THAT DAY IN A ROW
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2707849
10/17/19 09:01 PM
10/17/19 09:01 PM
BradH Offline
BradH  Offline
I'll take a s.w.s.w.a.g. it's running 97-98 MPH in the 1/8th, and would have gone 11.0-11.1 at 121-122 in the 1/4. His 1/8th #s are very close to what mine were for a solid 11.0 pass. It took a 1.51 60, a 6.9x at 98+ 1/8th and 122+ MPH to squeak into the 10.9s.
How much you gonna spray it?
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: n20mstr] #2707893
10/18/19 12:01 AM
10/18/19 12:01 AM
San Diego, CA
mopar_man619 Offline
San Diego, CA
I wanna see a picture of this beast. like the combo!
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: NEW BEST Mopars at the valley Junkyard 360 magnum [Re: BradH] #2707928
10/18/19 07:33 AM
10/18/19 07:33 AM
N
N
when it was straight from the junkyard, we used to run 52n 48f and take a ton of timing out to slow it to 11.50. With a little timing in it it would go 11.teens We upped it to 65n 52f and it ran 10.90s
NOW that was with stock pitons and a smoking ?? how many mile junkyard motor.
Now with a fresh shortblock, great heads and a forged piston...he want to use possibly a 73n that should be 175hp
Everything is waiting on the roll bar..LOL The car is too fast on motor now let alone using the plate again !
