common donut spare today? #2706920
10/15/19 08:11 AM
10/15/19 08:11 AM
Andrewh Offline OP
Andrewh  Offline OP
I remember reading many years back, using the mbody and maybe jeep donut spares work on the old mopars.
What is a good one today I might find in the yards?
While it says the modern mopar are the same bolt patter, I recall reading they were off by a bit. like 115 mm vs 114.3 or something.
I found wheel bolt pattern look ups, but nothing tells me what the center hole is. The couple I tried were way too small to get over the disc brake hub.
Re: common donut spare today? [Re: Andrewh] #2706929
10/15/19 09:18 AM
10/15/19 09:18 AM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
2003 Cadillac CTS compact spare works. It's a light aluminum rim and it fits in an A-body spare tire well. I'm not sure what all years will work, but the junk yard should know.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: common donut spare today? [Re: D149] #2706967
10/15/19 12:02 PM
10/15/19 12:02 PM
Andrewh Offline OP
Andrewh  Offline OP
ah, sorry, that must fit the small bolt pattern.
I was looking for the regular size 4.5 x 5.
Re: common donut spare today? [Re: Andrewh] #2706990
10/15/19 12:42 PM
10/15/19 12:42 PM
moparx Offline
moparx  Offline
the center registry hole on caravan 15 & 16" doughnut spares are the same as the early wheels, which is 2.810-2.820 until at least 2007. they are the same 115mm bolt center as well.
beer
Re: common donut spare today? [Re: moparx] #2707092
10/15/19 07:48 PM
10/15/19 07:48 PM
Andrewh Offline OP
Andrewh  Offline OP
thanks. so that confirms it for me 115 vs 114.3
so it is off by a bit. but for a spare I guess I won't worry.
Thanks. gives me a starting place.
Re: common donut spare today? [Re: Andrewh] #2707104
10/15/19 08:51 PM
10/15/19 08:51 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
I got one out of a Crown Victoria, fits my 70 Charger. I read all that in a long lost Mopar mag.
Re: common donut spare today? [Re: Andrewh] #2707196
10/16/19 08:46 AM
10/16/19 08:46 AM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
The Cadillac CTS spare is a 4.5" (Big) bolt pattern.
1999 Dakota R/T
2000 Viper GTS
Re: common donut spare today? [Re: D149] #2707262
10/16/19 12:25 PM
10/16/19 12:25 PM
moparx Offline
moparx  Offline
isn't the crown vic an aluminum wheel ?
i remember years ago, there was a 15x 4 or 4 1/2" wide spare in a couple of ford products that was aluminum.
i "think" you also had to open up the register hole a bit ?
i have only seen a couple of those floating around over the years. all at different times, or i would have bought a pair just because.
beer
