70 RR dust trail strip? #2701388
09/27/19 12:35 PM
09/27/19 12:35 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
So I got the set and laying them out.... little odd...
2 long pieces labeled right side- Fender door.....
2 long pieces labeled left side... fender door.
4 short ones...2 labeled right...2 labeled left... for the scoop to door I assume...
Did I just get 2 extra short ones.....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR dust trail strip? [Re: JMCFAN] #2702191
09/30/19 09:51 AM
09/30/19 09:51 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Yes you got two extra quarter panel pieces. MAKE SURE you have the feet of the stripe on the BOTTOM when installed. I can't tell you how many cars I've seen with the feet on top. Your first piece with the bird will show the foot on the bottom. AND the stripe is not in the center of the scoop. it is in line with the roadrunner emblem.
Re: 70 RR dust trail strip? [Re: LemonTwiist] #2702194
09/30/19 09:57 AM
09/30/19 09:57 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yes thanks! I cant find a good measurement for the stripe or the bird. I have the facorty one I think buts difficult to deceipher...
Re: 70 RR dust trail strip? [Re: JMCFAN] #2702231
09/30/19 11:40 AM
09/30/19 11:40 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Check the archives here, there was a thread on the bird & dust trail location a while back.
I remember looking through it and also some google images, and the dust trail is as stated, not centered in the scoop.
That's also what I recall from when they were new.
Some probably came through incorrect or uneven, though.
Rick Ehrenberg (Mopar Action & member here) seems to have the factory measurements for all that stuff.
Re: 70 RR dust trail strip? [Re: topside] #2704838
10/08/19 11:45 AM
10/08/19 11:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
according to the engineering drawing, the "dust trail" is not intended to be a straight line - it "wanders" up & down from its starting height
Re: 70 RR dust trail strip? [Re: 6bblgt] #2706774
10/14/19 05:40 PM
10/14/19 05:40 PM
canada
RRBB Offline
RRBB  Offline
canada
correct -the stripe goes about 1/3 down from the top of the scoop
