help with 1974 roadrunner #2706755
10/14/19 04:22 PM
10/14/19 04:22 PM
tx
N
nobrakesneeded Offline OP
N
tx
I am looking for a steering column diagram for a 74 roadrunner. I've found up to 1972, but know there are differences.
I'm missing a few pieces and need to see what I am missing so I can source them. Thanks.
Re: help with 1974 roadrunner [Re: nobrakesneeded] #2707521
10/17/19 09:05 AM
10/17/19 09:05 AM
IMGTX Offline
IMGTX  Offline
Are you looking at parts or wiring information?
The parts only changed a minimal amount. Somewhere around 71/72 the lock cylinder went from a bolt in pin to a spring loaded tab for a retainer.
As for the wiring it hasn't changed except some cars have a key in buzzer, lighted lock or cruise control, others don't.
Re: help with 1974 roadrunner [Re: IMGTX] #2707790
10/17/19 06:23 PM
10/17/19 06:23 PM
tx
N
N
tx
I was looking for hard parts inside the column. I think I've got a lead on a clean, rebuilt column that will be used.
Re: help with 1974 roadrunner [Re: nobrakesneeded] #2708046
10/18/19 12:38 PM
10/18/19 12:38 PM
IMGTX Offline
IMGTX  Offline
The good news is that not much changed in the columns that you are interested in.
69 and older have the key in the column and these are no help for you.
In 70 they went to the Key in column but the 1970 year also several unique features. A bolt held the lock cylinder in the column and there was an interlock system that required you to be in park or Reverse to remove the key. These are not worth your time, leave them for the 70 specific restorations.
In 71 and later they had 4 column types. Auto(Column shift), Auto/Manual (Floor shift), 3 on the tree, and tilt/telescoping. The Tilt/Telescope were actually GM columns.
They continued with these until late 80's early 90's on vans and trucks. I have used late 70's / 80's truck columns to convert Column shift auto columns to manual columns. Parts are easy to get from trucks/vans.
After that it is really just the shaft and extension tube that is the difference. That is why you probably won't see a whole lot of diagrams from later than 71. They really just didn't change. They did add a flex coupling in 73 and later B bodies because of the rubber isolated front K frames added another level of flex.
If you are getting a column check the length of the extension tube, and since you have a 74 you will have a flex coupling just past the base of the column. These were a metal & rubber biscuit that usually falls apart. The early ones were about 5/8" to 3/4" thick and are hard/expensive to find. You can stack a couple of the easily found later flex couplings which are about half as thick and made from nylon reinforced rubber (think tire tread with out the actual tread). These are available at Autozone.
Hopefully that is some help.
