NEW BEST Mopars at the valley Junkyard 360 magnum
#2706687
10/14/19 12:51 PM
10/14/19 12:51 PM
Posts: 4,699 On the parachute mount
n20mstr
Car has no roll bar, Has been running 11.20's last couple times out on motor. They told my son at tech, Don't go faster than 11.50 1st pass off the trailer it goes 11.185 on the brakes LOL
guess its time for a roll bar, because he wants to start using the plate again ! LOL
....BAD A$$ STREET CAR.....
Re: NEW BEST Mopars at the valley Junkyard 360 magnum
[Re: n20mstr]
#2706694
10/14/19 12:58 PM
10/14/19 12:58 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Nice ,, roll bars are good for safety but adding extra lbs stinks.
6.50 @105.26
[Re: dvw]
#2706723
10/14/19 02:32 PM
10/14/19 02:32 PM
n20mstr
I am assuming junkyard short block with heads, cam , and intake? Magnum or LA? Doug was a complete junkyard engine with an intake and a cam. was going 12 teens on motor, best of 10.90 on a plate Ball honed it, put a standard bore flattop in it. Edelbrock heads, and a slightly bigger cam. Still a street driven everywhere car, pump gas, Went 7.03 three times in the 1/8 so im assuming it will go 10.9x on motor now The air was great also, 270' and only 38 water grains It has been running 11.20s in the summer
[Re: Kindafast]
#2707094
10/15/19 08:01 PM
10/15/19 08:01 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Nice ,, roll bars are good for safety but adding extra lbs stinks. They also stiffen up the chassis to allow for the quick elapsed times. So in my opinion it’s good weight.
[Re: actionange]
#2707188
10/16/19 08:30 AM
10/16/19 08:30 AM
Kindafast
Seaford, Va
Nice ,, roll bars are good for safety but adding extra lbs stinks. They also stiffen up the chassis to allow for the quick elapsed times. So in my opinion it’s good weight. Agreed , it will stiffen the car and help with ET sometimes but they are still heavy. And a PITA to get around when you are old like me. LOL
6.50 @105.26
[Re: n20mstr]
#2707191
10/16/19 08:38 AM
10/16/19 08:38 AM
BradH
[Went 7.03 three times in the 1/8 so im assuming it will go 10.9x on motor now Not sure it's an apples-to-apples comparison, but my junk was stuck in the 11.0s when it ran 7.0s in the 1/8th; had to start dipping into the 6.9s to squeak out a best of 10.97 w/ that build.
[Re: Kindafast]
#2707339
10/16/19 06:37 PM
10/16/19 06:37 PM
actionange
anywhere@ anytime
Nice ,, roll bars are good for safety but adding extra lbs stinks. They also stiffen up the chassis to allow for the quick elapsed times. So in my opinion it’s good weight. Agreed , it will stiffen the car and help with ET sometimes but they are still heavy. And a PITA to get around when you are old like me. LOL I’m OLD as well but consider climbing over my non swing out roll cage side bar EXERCISE! 🤪👍
[Re: actionange]
#2707348
10/16/19 07:01 PM
10/16/19 07:01 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Nice ,, roll bars are good for safety but adding extra lbs stinks. They also stiffen up the chassis to allow for the quick elapsed times. So in my opinion it’s good weight. Agreed , it will stiffen the car and help with ET sometimes but they are still heavy. And a PITA to get around when you are old like me. LOL I’m OLD as well but consider climbing over my non swing out roll cage side bar EXERCISE! 🤪👍 Well you would get a kick out of seeing my fat, smelly, old azz climbing in and out of my drivers side window every time I pull my car in and out of my enclosed trailer.
[Re: pittsburghracer]
#2707404
10/16/19 09:22 PM
10/16/19 09:22 PM
Kindafast
Seaford, Va
Dang I can't get that picture out of my mind now LOL
6.50 @105.26
[Re: Kindafast]
#2707412
10/16/19 09:51 PM
10/16/19 09:51 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Dang I can't get that picture out of my mind now LOL Now to add to the story I have been known to wear short shorts in our sweaty ball Pa summer weather. 😂
#2707452
10/17/19 12:43 AM
10/17/19 12:43 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Dang I can't get that picture out of my mind now LOL Now to add to the story I have been known to wear short shorts in our sweaty ball Pa summer weather. 😂 Sounds like it is time for a good electric winch in your enclosed car trailer ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: HardcoreB]
#2707579
10/17/19 10:49 AM
10/17/19 10:49 AM
n20mstr
Nice!!!...care to give details of the build? weight? JUNKYARD magnum 360. ballhone, flattop forged piston standard bore, zero deck , rings gapped LOOSE .035 , because we like to SPRAY Stock recon rods, replaced rod bolts ATI damper (Got to have one good piece keeping the stock crank and rods in there..LOL ) Comp Cam ( I don't know the specs, cam card at home) Ported Edelbrock heads RPM air gap intake Brawler carb, I think its an 850 Small headers I had laying around from the late 70's 3.5" exhaust to some stubby race mufflers with an X pipe PTC 9.5" converter, stock rebuilt 904 , low first gear 2.76 ( NO man valve body) Ford explorer 8.8 rear with stock 4.10 gears, ford motorsport posi unit, stock axles im pretty sure it weighs 3200 with him in it Its not my car, so that why some stuff im not 100% on...LOL
[Re: BradH]
#2707646
10/17/19 01:06 PM
10/17/19 01:06 PM
n20mstr
What does it 60-ft, and what MPH did it make in the 1/8th on those 7.0 passes? NOT SURE ON THE MPH, BUT IT PRINTS TIMESLIPS CONSITSTENT LOL 1.54 , 7.03 EVERY PASS 3 TIMES THAT DAY IN A ROW
[Re: n20mstr]
#2707893
10/18/19 12:01 AM
10/18/19 12:01 AM
Posts: 340 San Diego, CA
mopar_man619
San Diego, CA
I wanna see a picture of this beast. like the combo!
1967 Plymouth Valiant Gen III Hemi 11.42@119 youtube.com/moparman619
[Re: BradH]
#2707928
10/18/19 07:33 AM
10/18/19 07:33 AM
n20mstr
I'll take a s.w.s.w.a.g. it's running 97-98 MPH in the 1/8th, and would have gone 11.0-11.1 at 121-122 in the 1/4. His 1/8th #s are very close to what mine were for a solid 11.0 pass. It took a 1.51 60, a 6.9x at 98+ 1/8th and 122+ MPH to squeak into the 10.9s.
How much you gonna spray it? when it was straight from the junkyard, we used to run 52n 48f and take a ton of timing out to slow it to 11.50. With a little timing in it it would go 11.teens We upped it to 65n 52f and it ran 10.90s NOW that was with stock pitons and a smoking ?? how many mile junkyard motor. Now with a fresh shortblock, great heads and a forged piston...he want to use possibly a 73n that should be 175hp Everything is waiting on the roll bar..LOL The car is too fast on motor now let alone using the plate again !
