Re: 7 sec car Radiator
[Re: Raffaplymouth60]
#2708565
10/20/19 02:39 PM
10/20/19 02:39 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Is it possible that you have air trapped in the cooling system? Looks like the highest point is the thermostat housing. maybe needs a bleed screw to just to be purged the air out of the system?
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: racerhog]
#2742003
02/11/20 04:12 PM
02/11/20 04:12 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hello Guys ! i bought a new Big Radiator... im working for installation... but also with this the water neck look like a little bit higher than radiator ... i hope can make air in the circuit ... im also undecided if put a reservoir tank or not ?
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
[Re: BradH]
#2746160
02/24/20 04:49 PM
02/24/20 04:49 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hello , got is now hoses and new billet water neck filler .... is a little bit higher than the radiator ... i hope no more air inside.. expansion tank will be from water filler , i installed 25lb cap in the radiator and 19 lb cap on the filler
[Re: 1980volare]
#2746342
02/25/20 09:27 AM
02/25/20 09:27 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
My junk runs mid to low 8s, I run a cheap summit brand one,i think it’s for a camaro or something. 3 core, mounted under the trunk floor, Taurus fan, meziere electric pump. Can cruise all day never gets over 170-180 Apples to oranges here. A new style engine w/ a turbo won't build nearly the amount of heat as the OP's engine will. I have several friends w/ GM LS powered turbo cars that are FAST and the cooling systems they use (like yours) make me jealous, lol.
[Re: an8sec70cuda]
#2746376
02/25/20 11:52 AM
02/25/20 11:52 AM
Posts: 195 Italy
Raffaplymouth60
Italy
This is 7.80 car ,with 350 of nitrous shot , in italy in the summer ... 95/100 f
