Re: 727 Damage/Repair Advise
[Re: dvw]
#2705140
10/09/19 11:31 AM
10/09/19 11:31 AM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Lets see what the clutch fibers look like. Hold the reaction support up to the light. Are the ring grooves square? Or are they worn tapered. Are the rings worn on the sides? How about where the reaction shaft support rings ride in the drum, worn? 4 clutch drum should function fine with a Turbo Action rmvb. Have you checked the pressure regvalve and spring? I'd be testing the resource when its backtogetherT/A arent real high 120ish. Doug Rings look good,grooves as well. I ordered a kit with Teflon seals and a roller rear support. Clutches? BALD I will post some pics of them later
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2705169
10/09/19 01:03 PM
10/09/19 01:03 PM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
Your valve body has damage in the same area I have circled. Is this a modification or is this wall damaged? No,not damage. Thats the way they are made. PDF. file on T/A website clearly shows it this way. I went back and looked after you pointed it out. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Either way I will be comparing their picture to my actual part..... Okay, That must be a Turbo Action mod for the reverse pattern, just wondering about the looks of that wall.
[Re: GODSCOUNTRY340]
#2705173
10/09/19 01:13 PM
10/09/19 01:13 PM
6bblFLASH
N.E. Ohio
Clutch pictures. Rear shows some slip,but not failed
[Re: 6bblFLASH]
#2705341
10/09/19 10:47 PM
10/09/19 10:47 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
Looking at your valve body, you have the part throttle kickdown (PTK) module attached. It is a small casting piggy backed to the side of the valve body opposite side of the gear selector/manual valve. The Cheetah RMVB should not have that PTK attached. Look at the Turbo Action website under instructions and look for 17156 Upper Valve Body Assembly. You would need 3 short screws to delete the PTK module.
Of course check the Turbo Action model number on the valve body top plate 4 or 6 screws. Should be etched in: 17156-XXAAAA, XX is the year and AAAA is the serial # extension. If you don't have a 17156, verify the number on the website and/or call Paul Forte at TA.
Also, I would carefully check your clutch clearances upon reassembly. Direct clutches should be around 0.015" per friction disc. 4 clutches would need about 0.060" clearance and 5 would need 0.075". The forward clutches should be about 0.028" - 0.035" MAX total. I use the RAYBESTOS TAN waffle clutches in the direct and grayish RAYBESTOS clutches in the forward drum. No Kolene steels.
I would recommend a 2 spring front servo with a 4.2 band lever. Red solid backed kickdown band, not Kevlar. As mentioned before, double check your reaction shaft support sealing rings. Teflon are best. Also replace the drum bushing and check for wear in the drum sealing ring area. I would use 12 springs in the direct drum. Remove the accumulator spring if present and install a 1/2" diameter blocker rod with an approximate length of 2.95". Check to make sure the valve body will sit flush. If not, trim the blocker rod slightly until VB sits flush.
Set gear train and input shaft end play to the lower end specs. Also, Use a selective FLAT snap ring in both drums for setting clearance. Set the front band lever using an old over-running clutch roller (5/16" diameter) like setting mechanical rocker valve lash.
If you have any further questions, e-mail or PM. Glad to help.
John
[Re: DusterW2]
#2705373
10/10/19 02:02 AM
10/10/19 02:02 AM
6bblFLASH
N.E. Ohio
OK thanks for the info. I will look into all those issues. That "PTK" cover. I seen that it isn't in the PDF illustrations for my part number VB. I can just make a flat blocking plate to take its place.
I bought this VB new in 1986 was in my Cuda until 2009 when I put a Jericho in that . Never had any failures in thousands of passes. Not happy in this street application
[Re: 6bblFLASH]
#2705414
10/10/19 08:22 AM
10/10/19 08:22 AM
GODSCOUNTRY340
Didn't know you used that VB in another trans. Since that is a manual shift body you have to block off the governor in the tailshaft. If you don't the trans will attempt to shift on it's own while you are trying to force shift it throughout the valve body, could cause problems.
#2705447
10/10/19 09:37 AM
10/10/19 09:37 AM
6bblFLASH
N.E. Ohio
Didn't know you used that VB in another trans. Since that is a manual shift body you have to block off the governor in the tailshaft. If you don't the trans will attempt to shift on it's own while you are trying to force shift it throughout the valve body, could cause problems. Confused?? I thought the valve body did that by design? I do plan on removing the governor now that its off anyway. Is there something else that is required?
#2705516
10/10/19 12:48 PM
10/10/19 12:48 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
. Since that is a manual shift body you have to block off the governor in the tailshaft. If you don't the trans will attempt to shift on it's own while you are trying to force shift it throughout the valve body, could cause problems. Uh, no. The manual VB has the automatic shift components removed.
[Re: dvw]
#2705526
10/10/19 01:11 PM
10/10/19 01:11 PM
GODSCOUNTRY340
My B&M reverse pattern, manual shift valve body purchased in the mid '70's required the governor to be blocked or removed. These newer ones might not need it.
#2705660
10/10/19 06:54 PM
10/10/19 06:54 PM
Posts: 28,633 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
My B&M reverse pattern, manual shift valve body purchased in the mid '70's required the governor to be blocked or removed. These newer ones might not need it. Cope and T/A both told me to block mine so I did. Also used the A&A billet stuff
