440 Mechanical six pack PCV valve ??? #2704963
10/08/19 08:13 PM
10/08/19 08:13 PM
Garagemahal
Milan454 Offline OP
Milan454  Offline OP
Garagemahal
Hi gang, I'm looking for input for a PCV valve for a hopped up engine with 12 inches of vacuum at idle in park. Oh and it can't be made of unobtanium.
I started with a Fram PV163. The idle was so high I could not adjust the carbs even close to seeing the transfer slot.
I then did a web search and learned that a valve from a s10 2.2 liter flowed significantly less at idle. So I installed an ACDelco 19313315. The idle dropped significantly and I think I'm going to stick with this PCV for my larger canned engines.
Thoughts???
Thanks!!
Re: 440 Mechanical six pack PCV valve ??? [Re: Milan454] #2704978
10/08/19 09:02 PM
10/08/19 09:02 PM
Washington
madscientist Offline
Washington
Thoughts???
Thanks!!
You might as well bite the bullet and call M.E. Wagner and buy one of their adjustable valves. None of the junk you buy today is worth bothering with.
Re: 440 Mechanical six pack PCV valve ??? [Re: madscientist] #2704989
10/08/19 09:46 PM
10/08/19 09:46 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Thoughts???
Thanks!!
Yep. Worth every penny.
All day long. Twice on Sunday.
Re: 440 Mechanical six pack PCV valve ??? [Re: A990] #2705037
10/09/19 04:56 AM
10/09/19 04:56 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Yep
This thing is slick as whaleshit
Any one have an image installed on a chrysler VC
Or you can gut pcv valve and hide it under Air cleaner
Wagner Valve
Re: 440 Mechanical six pack PCV valve ??? [Re: sogtx] #2705321
10/09/19 09:32 PM
10/09/19 09:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a stock type PCV valve in my 493 and it works great. I don't remember what it is listed for as I have a few around the garage and ended up using this one because it works fine on my combo. I have a good idle and the eng pull's enough vacuum at part throttle that the valve works good. I have been running this PCV valve for about 8 years. Ron
Re: 440 Mechanical six pack PCV valve ??? [Re: Milan454] #2705502
10/10/19 12:08 PM
10/10/19 12:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I run the old Direct Connection mechanical carbs too. Absolutely love them. Motor idles around 7" of vacuum. The stock Mopar specific PCV works fine in mine. No fast idle issues at all.
Maybe it's something else? You can make a flow restriction plug and stuff it in your PCV line. Drill a smaller hole in it to reduce the air flow. I did that on my old slant 6, and it worked perfectly.
