RMVB with brake ?? #2704547
10/07/19 11:22 AM
10/07/19 11:22 AM
moparx Offline OP
moparx  Offline OP
is it possible to swap a RMVB with a brake over to a valve body without a brake ?
is there anything needed done to the transmission in order to do so ?
TIA as always ! bow
beer
Re: RMVB with brake ?? [Re: moparx] #2704585
10/07/19 01:37 PM
10/07/19 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most trans brake installations require drilling a bleed hole in the front clutch drum/piston. Not needed without the brake but some non-brake setups probably work OK with the hole.
Re: RMVB with brake ?? [Re: John_Kunkel] #2704822
10/08/19 10:59 AM
10/08/19 10:59 AM
moparx Offline OP
moparx  Offline OP
thanks for your reply John. up
beer
