more progress ! new best ET #2704368
10/06/19 04:59 PM
10/06/19 04:59 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Went to Cecil county streetcar shootout. Air was killer but track was not there 100% lots of cars were knocking the tires off.
First pass went a 5.15 with a cold 800lb bottle ( it was 55*) next pass had a 900 psi bottle but missed the front shock setting. Knocked the tires off.
Next pass went a 5.08, First round i lost but went a 5.07 , getting there slowly.....without just taking the easy route of upping the nitrous jet lol
....BAD A$$ STREET CAR.....
Re: more progress ! new best ET [Re: n20mstr] #2704395
10/06/19 06:47 PM
10/06/19 06:47 PM
Guitar Jones Offline
That's smokin'.
Re: more progress ! new best ET [Re: n20mstr] #2704435
10/06/19 08:41 PM
10/06/19 08:41 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Killer cool
Re: more progress ! new best ET [Re: racerx] #2704455
10/06/19 10:24 PM
10/06/19 10:24 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's huffin! Good to see you out and testing. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: more progress ! new best ET [Re: racerx] #2704456
10/06/19 10:24 PM
10/06/19 10:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Daaaang!
'63 Dodge 330
11.19 @ 121 mph
Re: more progress ! new best ET [Re: GY3] #2704486
10/07/19 05:12 AM
10/07/19 05:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That 4 second run is coming.
Doug
Re: more progress ! new best ET [Re: dvw] #2704814
10/08/19 10:42 AM
10/08/19 10:42 AM
an8sec70cuda Offline
Doug
iagree VERY nice! up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: more progress ! new best ET [Re: an8sec70cuda] #2705063
10/09/19 08:33 AM
10/09/19 08:33 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
UPcoming off season, have to figure out this 60' car probably needs a little more gear.
its 90lb over weight
and its getting to that time to max out the plate
the fastest cars are going 4.58 @ well over 150. I have been 140.56 , I think 145? might be my limit, then I need more motor I think lol
Re: more progress ! new best ET [Re: n20mstr] #2705070
10/09/19 08:49 AM
10/09/19 08:49 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is your season "done"?
Re: more progress ! new best ET [Re: BradH] #2705074
10/09/19 09:04 AM
10/09/19 09:04 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
most likely yes, there are some issues that have to be figured out with the nitrous progressive, and gearing. There seems to be a lot of potential in the combination.
Re: more progress ! new best ET [Re: n20mstr] #2705077
10/09/19 09:10 AM
10/09/19 09:10 AM
BradH Offline
BradH  Offline
Understood. I was wondering if you might be coming back down to Cecil County again this fall so I could come check it out in person. Or, I'll get up their next spring...
Re: more progress ! new best ET [Re: BradH] #2705832
10/11/19 10:48 AM
10/11/19 10:48 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Your car continues to impress!
Re: more progress ! new best ET [Re: HardcoreB] #2705857
10/11/19 11:32 AM
10/11/19 11:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like it is running really well and you continue to chip away at it. But by the sounds of it you are gonna need a lot more nitrous jet to keep up with the guys at the top.
Re: more progress ! new best ET [Re: Al_Alguire] #2705863
10/11/19 11:42 AM
10/11/19 11:42 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Great running car for sure. The only huckleberry is this is new best weather at what was probably at one of the “super tracks” that always throw out killer runs this time of years. The test n tuners live for this time of year. Keep at it as I know you will. Josh just came out will his new rules and format for next years monster Mopar king of street class. We shall see if the no clocks on helps or hurts the car counts. The spectators will brobably hate it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: more progress ! new best ET [Re: BradH] #2705875
10/11/19 12:14 PM
10/11/19 12:14 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Looks like you going to get your wish....they are having Ultra at the last race , Nov 2nd.
So YES, I should be there one more time this season
Re: more progress ! new best ET [Re: Al_Alguire] #2705878
10/11/19 12:18 PM
10/11/19 12:18 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Got three more jets to go up ….roughly 400 more PPH of nitrous left.
The car is 90lbs over the weight
Plus its trial and error time with the gear. Im 1.48 X 4.10 right now. Popular? right now seems to be 1.52-1.58 with 4.29 or 4.56, but who really knows. These guys talk, but can you really trust them??? LOL
I try NOT to listen to what other racers say they have/do..
Re: more progress ! new best ET [Re: pittsburghracer] #2705881
10/11/19 12:19 PM
10/11/19 12:19 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Yes air was killer, but the track was NOT. Also I was still probably 2 numbers too low on the carb jets as the AF was not where it has been when it runs its best MPH
Re: more progress ! new best ET [Re: pittsburghracer] #2705898
10/11/19 01:08 PM
10/11/19 01:08 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Really.... no clocks? I hadn't heard that. As its an all Mopar show, mainly for fun, cant say as i like the idea of not knowing what these cars run. Takes a lot of the fun out of it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: more progress ! new best ET [Re: B3422W5] #2707547
10/17/19 09:57 AM
10/17/19 09:57 AM
B3422...I agree. I'd much rather see the clocks on. I understand there are some that grudge race and all, but having the clocks turned off sucks IMO.
n2omstr...It's funny what you said about not listening to other racers. I've found the same thing for the most part. A lot think the setup is all a big secret and don't want to help. Myself, I'd rather help someone out if I could. I've just decided to try stuff and see for myself.
CHIP
Re: more progress ! new best ET [Re: an8sec70cuda] #2707583
10/17/19 10:56 AM
10/17/19 10:56 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
My self, I think Josh is making a mistake. I honestly think the guys he changed the format for are not really going to support his race. BUT if they say the coming and want to race me with clocks off....BRING IT. DO they really want to show them getting beat or beating a 5.0 (for now, maybe faster by then ) car like me??? Whatever happens I don't car, I want to support the race and its fun.
As for getting advice from other Ultra Street guys...I don't ask, and I don't listen to what they offer, well with a grain of salt...lol
The record now just got plunged to a 4.53...discouraging to say the least. Im a test and tuner in Ultra, that's all. I cant afford the R and D that these guys do, the money they spend is crazy $$$$$
