Big block 4 Speed Starter not engagement #2704210
10/06/19 01:47 AM
10/06/19 01:47 AM
Italy
Raffaplymouth60 Offline OP
Italy
Hello .. i have starter problem on my 512 4 speed .. this is my combo :
512 ( 440 Block )
8 Bolt ctankshaft .
steel Flywheel 8 bolt
bellhousing reproduction from Brewers aluminium
a833 4 speed 1969
centerforce clutch
Starter powermaster 9533
Headers TTI 2" 3.5
last week i started the engine ... everything ok ! ... after a week .. i have installed new fuel pump and other parts ... try to start and not engage... not engagement... i have checkhed all bolts ... all ok you have idea ?
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Big block 4 Speed Starter not engagement [Re: Raffaplymouth60] #2704213
10/06/19 02:50 AM
10/06/19 02:50 AM
I haven't used that starter but the Power Master starter on my S/P car had the front retaining ring pop off at the races several years ago which made the starter not work when engaging, it would spin but not engage and spin the flywheel over rant whiney
Re: Big block 4 Speed Starter not engagement [Re: Cab_Burge] #2704275
10/06/19 10:15 AM
10/06/19 10:15 AM
Italy
Italy
PROBLEM SOLVING WAS BAD THE NEW STARTER ! INSTALLED ANOTHER ONE FROM DAKOTA DODGE AND NOW IS OK ! POWERMASTER NOT GOOD !
