Re: Scratched bore reassembling shortblock [Re: Cab_Burge] #2703636
10/03/19 11:16 PM
10/03/19 11:16 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
um I mag my own stuff at my friends shop that has been building my motors and my fathers motors for over 45 years. So no i did not miss this. I have assembled alot of motors and made a mistake. Thanx for alll the opinions WOW
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703681
10/04/19 04:14 AM
10/04/19 04:14 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Let us know what it runs once you have it back together!
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703760
10/04/19 10:53 AM
10/04/19 10:53 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
So what does it look like after the hone?
Kevin
Re: Scratched bore reassembling shortblock [Re: Twostick] #2703908
10/04/19 06:17 PM
10/04/19 06:17 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
71Pan- I don't think anyone was talking down to you. People were just giving you their best advice based on their experiences and we all have a little passion around this type of stuff. Please report back what you find and how it goes. Good Luck!
Re: Scratched bore reassembling shortblock [Re: BigBlockGTS] #2704029
10/05/19 08:25 AM
10/05/19 08:25 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Thanx bore looks pretty good. Motor together
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2704041
10/05/19 09:24 AM
10/05/19 09:24 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
did that myself once on a 318 Magnum, somehow the skinny lower rail on an oil ring got folded over.... soon as piston cleared the ring compressor and wouldn't move I went "ohhh $#!t..." took it back and had it re evaluated at machine shop, they honed it out and said "run it".... but I'm afraid to... that was 10 years ago and that bare block is still sitting unused.... gonna get it bored and buy matching pistons to the new bore when it gets used.... 0.007" bore to piston clearance on that one hole seems too much (I don't have forged pistons and this engine isn't being built to crazy enough power levels to need them)
Re: Scratched bore reassembling shortblock [Re: volaredon] #2704136
10/05/19 04:25 PM
10/05/19 04:25 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Have the skirt coated on one piston, call it good.
Re: Scratched bore reassembling shortblock [Re: Jeremiah] #2704245
10/06/19 08:57 AM
10/06/19 08:57 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I wouldn't fret much over being a couple thou over size in the bore. Will change your ring gap more than anything else.
Re: Scratched bore reassembling shortblock [Re: Mopar Sam] #2704813
10/08/19 10:35 AM
10/08/19 10:35 AM
an8sec70cuda Offline
Originally Posted by Mopar Sam
Hone it and run it. Less area there than in your ring gap.You ought to see what dirt track guys run.
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Scratched bore reassembling shortblock [Re: an8sec70cuda] #2704863
10/08/19 01:31 PM
10/08/19 01:31 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Thanks for posting motor back together,This the first motor ever i didnt total assembly my self heads valve springs etc. I found 1 guess 939 springs i guess on the heads. The box listed 936 spring Difference 130lb at 1.950 370 @1.350= 936 sprngs on motor are 145 @1950 426 at 1.9250 I guess 939 both 1,538 odi break cam in without inner springs and Amzoil br oil. Everything went great.I bought head fully ported 360-1 heads by BGR Called Bob abut heads he had flow numbers about heads t he motor was built by BGR racing,Long story short to motor to my guy flowed heads and put crank connecting rods
s bore honed assembleds heads etc. put whole motor together. Had indy rocker on motor and could not keep lash. Just set valves took it out starting popping at 6900. Number on rocker pushed out adjuster flatten cam, cam 271 @ 50 637 lift used aszoil oil. Going with tool steel lifters 266 @ 50 cam .637motor is 11.66 to one buying HS rockers also.Going back to doing everything spring height assembly EVERYTHING, Been doing thin for 35 years , Some thing my father told me i did to due always, Cleanliness Patience and measure everything TWICE . My fault fault for not following procedure
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2704949
10/08/19 07:08 PM
10/08/19 07:08 PM
Would you please post another picture of that scratch in that cylinder after running it work
Re: Scratched bore reassembling shortblock [Re: Cab_Burge] #2705012
10/08/19 10:51 PM
10/08/19 10:51 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
That would be very interesting and educational
