Cooling Issue #2703440
10/03/19 03:13 PM
10/03/19 03:13 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
The other day my 2001 Dodge Ram with a 5.9 overheated. It was bowling over so i waited till it was cooled off and put water in it till i figure it out. The engine runs fine so i don,t think i blew a head gasket but when I run it all the hoses get hot but the lower hose is cold. Is it a blocked radiator or what is your opinion on the problem????
Re: Cooling Issue [Re: 72 RR DUDE] #2703451
10/03/19 03:38 PM
10/03/19 03:38 PM
pull/check the thermostat for a start
