1971 Road Runner cornering light switch?? #2703390
10/03/19 12:41 PM
10/03/19 12:41 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
After digging thru a couple different schematics, I finally found out what this 3 wire plug is for, but I have never heard of it before! Ever heard of the cornering light switch? What is it and where would I find it? Critical to wire it up or just let it be? I found no such mating connector in the "original" harness. I should add that this plug is coming out of the column in the same area as the ign switch and turn signal wiring.
Karma has no menu. You get served what you deserve.
Re: 1971 Road Runner cornering light switch?? [Re: SKR8PN] #2703393
10/03/19 12:52 PM
10/03/19 12:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cornering lights were standard on 1971 Imperials & optional on Chrysler models - http://www.hamtramck-historical.com...aBook/1971/71_Chrysler_Features_0014.jpg
Re: 1971 Road Runner cornering light switch?? [Re: Alaskan_TA] #2703419
10/03/19 02:01 PM
10/03/19 02:01 PM
SKR8PN Offline OP
SKR8PN  Offline OP
Thanks! Guess I won't worry about it then!
