Re: Removing 1 3/4 hooker super comp headers,360 bbody?
[Re: Joesixpack]
#2703140
10/02/19 05:25 PM
10/02/19 05:25 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
If those are a 1 piece header, then on an a body anyway, here's what has to be undone...both motor mounts, starter, drag link, oil filter adapter, rad hoses, coolant, remove distributor so when you jack up the motor it won't hit the firewall. Don't fight it, just pull the parts. Make sure you have the adapter gaskets first. Now some A body hooker 1 3/4 super comps are two piece, and I could drop those will a lot less fuss. And definitely high enough in the air so that you have room to manuever the header from the bottom. Mine always went in from the bottom - the only way from the top was while installing the engine.
[Re: bobby66]
#2703270
10/02/19 10:57 PM
10/02/19 10:57 PM
Posts: 3,505 DFW
mr_340
DFW
If I have to put in another set of headers on my A-bodies, I think I will cut the flanges and cut the collectors off so I can put in one tube at a time, or two for the center pair. Buy slip on collectors and weld on the links.
Floyd Lippencott IV
[Re: mr_340]
#2703373
10/03/19 11:40 AM
10/03/19 11:40 AM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
I have pretty much the same headers in my Duster. I don't have the right angle adapter, but with the filter off and the starter out they go right in from the bottom once you get the car high enough. I have Schumacher mounts and did have to ding a couple tubes for torsion bar clearance.
