AC ?? #2702537
10/01/19 10:03 AM
10/01/19 10:03 AM
Halifax, VA.
moparjack44 Offline OP
Halifax, VA.
On my 48 DeSoto hot rod (Vintage Air), the AC works great for about 1 hour. Then it "looses It's cool". Seems to be still working, fan blowing good, but AC temp increases until almost not cooling. Has been recharged, checked for leaks, none found. Engine temp running at 190F. Suggestions??
Jack
K.I.S.S.
Re: AC ?? [Re: moparjack44] #2702560
10/01/19 10:47 AM
10/01/19 10:47 AM
moparx Offline
moparx  Offline
you may want to call vintage air to see if they can help you diagnose this.
have you done a pressure check [high/low sides] when this happens ?
beer
Re: AC ?? [Re: moparx] #2702563
10/01/19 10:51 AM
10/01/19 10:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Evaporator freezing up. My 15 Colorado work truck would do that on the run to El Paso, about four hours into the drive, no AC, turn off AC let fan run and melt the ice, AC works.
Never bothered to get it fixed. But usually when you are low on freon the evaporator freezing is a symptom. I know it's been checked, but being a nonstock application you might need a bit more freon in it. What do the pressures and ambient temps look like?
Re: AC ?? [Re: Sniper] #2702573
10/01/19 11:18 AM
10/01/19 11:18 AM
Andrewh Offline
Andrewh  Offline
so the heat valve is supposed to be plumbed in at a specific way.
I think it has to be on the output side of the heater core instead of what you would expect the inlet.
It has to use the "drag" of the heater core to help stop the flow.
If it is plumbed in wrong, it allows the hot coolant to push past it.
Eventually it overwhelms the a/c and you get warm/ hot air.
The question is of course has it always done this, or is it a recent thing?
Re: AC ?? [Re: moparx] #2702598
10/01/19 12:39 PM
10/01/19 12:39 PM
Halifax, VA.
Halifax, VA.
beer
No pressure check done. Good idea, will see if I can contact Vintage Tech.
Thanks,
Jack
K.I.S.S.
Re: AC ?? [Re: Sniper] #2702600
10/01/19 12:42 PM
10/01/19 12:42 PM
Halifax, VA.
Halifax, VA.
Pressures, don't know. Ambient temp Sunday (last failure) 94F.
Jack
K.I.S.S.
Re: AC ?? [Re: Andrewh] #2702602
10/01/19 12:45 PM
10/01/19 12:45 PM
Halifax, VA.
Halifax, VA.
Always. Any suggestions? Can you simplify (I'm old and stupid, not necesarrily in that order). Simplier, the better.
Jack
K.I.S.S.
Re: AC ?? [Re: moparjack44] #2702642
10/01/19 02:29 PM
10/01/19 02:29 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
It sounds to me like your evaporator core is freezing up, which is something the system compensates for with a drain (so water condensing on the evaporator core can drain). 1st thing I'd check is to see if the drain is clogged.
If it is not clogged, I would check with the vendor and find out how their system prevents core freeze, they may pass coolant continuously through the heater core and have a hot air bleed somewhere that keeps the evaporator from icing up. There might be a fail in there somewhere.
Hope that helps.
Re: AC ?? [Re: moparjack44] #2702644
10/01/19 02:32 PM
10/01/19 02:32 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
basic a/c diag. if you do not have/system not equipped with evap temp sensor to cut off compressor when system is cold, system will continue to operate thus freezing the "h" valve causing it to freeze over and not cool. next time it happens, shut a/c off for 90-120 seconds and turn back on, if it cools again, "h" valve is freezing over from over work. then it would need a compressor cycling system of some kind.
Re: AC ?? [Re: rbkt65] #2702648
10/01/19 02:44 PM
10/01/19 02:44 PM
BcudaChris Offline
BcudaChris  Offline
Yeah, I put a cycling switch in when I did my R134 upgrade and box re-seal. That's the real fix.
Re: AC ?? [Re: BcudaChris] #2702655
10/01/19 03:30 PM
10/01/19 03:30 PM
Halifax, VA.
Halifax, VA.
Hope that helps.
I did find a bad crimp in one of the drain hoses, so I replaced the plastic with a rubber hose. Then the other plastic hose came lose and water drained into the floor board. I now have replaced that plastic drain hose with a rubber one. Have not used the AC since.
K.I.S.S.
Re: AC ?? [Re: Sniper] #2702690
10/01/19 05:09 PM
10/01/19 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, and a low refrigerant charge will cause that. Only way to correctly charge a system is by weight, evacuate and recharge by weight.
Re: AC ?? [Re: John_Kunkel] #2702714
10/01/19 06:43 PM
10/01/19 06:43 PM
Andrewh Offline
Andrewh  Offline
ok since it has always done it, I still say you put the valve in wrong.
That is assuming you had gauges on it at somepoint and know it has a full charge.
The problem is the actual valve does not have enough stopping power so they have to put it in an odd place.
So
Engine --> heater core --> Valve --> to engine.
The valve has a direction printed on it.
normally you would think you could do
Engine --> valve --> Heater core --> engine
But if you did that, the valve can't hold back the pressure from the engine and hot water will start to flow into the heater core.
It will eventually get too hot for the a/c to overcome and you lose cooling.
Re: AC ?? [Re: Andrewh] #2702927
10/02/19 09:46 AM
10/02/19 09:46 AM
Halifax, VA.
Halifax, VA.
Thanks everyone. I checked Vintage Air website, they have a very good online Tech, that was helpful also. I will check to sure upon original install, I did the correct order. Will be going on another long trip on Oct 11th to car show and drags at Dunn NC. I will let you know how/if the AC works OK..
Thanks,
Jack
K.I.S.S.
Re: AC ?? [Re: moparjack44] #2703084
10/02/19 03:28 PM
10/02/19 03:28 PM
BcudaChris Offline
BcudaChris  Offline
I'd bet you've got it to me.
Be interested to hear how it performs on your trip. If it drains adequately and still freezes up, I'd put in a clutch cycling switch if it is not already so equipped.
Re: AC ?? [Re: BcudaChris] #2703092
10/02/19 03:37 PM
10/02/19 03:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Is this on a flathead or did you swap something more modern in? I ask because I have a 51 Plymouth I want to add AC too, but keep the flat head.
Re: AC ?? [Re: moparjack44] #2703127
10/02/19 05:10 PM
10/02/19 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you suspect the water valve, disconnect it for this one trip and see how it cools. Also, if you suspect the water valve is the problem, feel the hoses on either side of the valve...with the valve closed one side should be cool.
Re: AC ?? [Re: Sniper] #2703365
10/03/19 11:17 AM
10/03/19 11:17 AM
Halifax, VA.
Halifax, VA.
No. It's a 1st Gen, 392 Hemi from 58 Chrysler.
K.I.S.S.
Re: AC ?? [Re: John_Kunkel] #2703367
10/03/19 11:21 AM
10/03/19 11:21 AM
Halifax, VA.
Halifax, VA.
I have the hot water valve close? Is that correct? It's just a "plumbers" valve with handle to turn water on/off manullay under the hood.
K.I.S.S.
Re: AC ?? [Re: moparjack44] #2703375
10/03/19 11:42 AM
10/03/19 11:42 AM
BcudaChris Offline
BcudaChris  Offline
If it freezes up with cleared drains, I'd open your hot water valve and the return a bit and see if that prevents the evap from icing up. You'll probably have to mess with it to get enough heat into the air to prevent freeze, but not enough to warm up your chilled air.
