4speed Linkage HELP #270217
03/29/09 11:07 AM
03/29/09 11:07 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I am trying to finish up this transmission and came to a stand still. I am working with a 67 trans with the Hurst conversion shifter to use the inland shifter lever. I had no levers or rods to start with. I have what I thought were the right parts, but nothing seems to be lining up. The trans is in neutral in this picture. All the rods seem to be to short. Do I have the wrong rods, or am I being a dunce here
Dan.
Re: 4speed Linkage HELP [Re: mopar4ya] #270218
03/29/09 12:13 PM
03/29/09 12:13 PM
Idaho
Runner Offline
Runner  Offline
Idaho
it looks to me like the wrong shift rods here is what i used when i xconverted my 68 satellite to a 4 speed. i used a 70 tranny but it should be the same. http://store.summitracing.com/partdetail...mp;autoview=sku
here it is on the tranny
[image]http://www.pbase.com/image/110725776.jpg
[/image]
Re: 4speed Linkage HELP [Re: mopar4ya] #270219
03/29/09 12:14 PM
03/29/09 12:14 PM
MO
cdp Offline
cdp  Offline
MO
This is from a 68 service manual. Since your using a hurst with a inland shifter conversion, you may be better off to get with Brewers Performance or Passon Performance for the correct parts.
Re: 4speed Linkage HELP [Re: cdp] #270220
03/29/09 12:15 PM
03/29/09 12:15 PM
MO
cdp Offline
cdp  Offline
MO
another view in the trans section of the manual.
Re: 4speed Linkage HELP [Re: cdp] #270221
03/29/09 12:59 PM
03/29/09 12:59 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Looks to me like the mounting plate could be wrong, the rods look correct. What is the number on the back of the aluminum plate? Should be 6348
If it is 6350 it is for an A body and will cause the rods to be short.
Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 4speed Linkage HELP [Re: Dan Brewer] #270222
03/29/09 02:44 PM
03/29/09 02:44 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Dan
Dan, you nailed it. I didn't know there were different mounting plates. The one I had on the transmission has a hurst #2298 on it. I found in my stash a 6348 and put it on. Everything lined up What does a 2298 fit?
Thanks!
Dan.
Re: 4speed Linkage HELP [Re: mopar4ya] #270223
03/29/09 03:03 PM
03/29/09 03:03 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
2298 plate is for 64-5 A-body.
Wayne
Re: 4speed Linkage HELP [Re: 64dodge572] #270224
03/29/09 03:09 PM
03/29/09 03:09 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Wayne
What he said. Very common, dad and I run into this all the time.
Dan
Re: 4speed Linkage HELP [Re: Dan Brewer] #270225
03/29/09 03:19 PM
03/29/09 03:19 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
You guys beat me to it, I too have a B-body that somehow got the A-body adapter.
B-body linkage and adapter attached.
