Re: I don't understand "Unsilenced Air Cleaner" [Re: Jeremiah] #2703920
10/04/19 06:55 PM
10/04/19 06:55 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I have wondered about air from the bottom being much hotter than from on top or the snorkel but I can't have everything
Facts are stubborn things.
Re: I don't understand "Unsilenced Air Cleaner" [Re: larrymopar360] #2704014
10/05/19 02:56 AM
10/05/19 02:56 AM
If you don't have a cold air system on your hood all air getting into the carb has to go through the radiator, correct work shruggy
The cold air bottoms on some of the OEM air grabber hoods had a front baffle on them to avoid tearing up the front of the air cleaner elements when the flaps where open for winter use from air blowing through the radiators scope
Re: I don't understand "Unsilenced Air Cleaner" [Re: Cab_Burge] #2704202
10/05/19 11:44 PM
10/05/19 11:44 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's a YouTube video of 440 dyno tests, with/without unsilenced air cleaner.
Without: 380 hp at 5500 rpm.
With: 375 hp at 5500 rpm.
https://www.youtube.com/watch?v=yLdSsFfnDEg
Go to 26:58 - 30:33, about 3.5 minutes.
(Later in the video they get 400 hp by switching to Edelbrock aluminum intake manifold from original cast iron.)
Re: I don't understand "Unsilenced Air Cleaner" [Re: kentj340] #2704297
10/06/19 11:39 AM
10/06/19 11:39 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Cool thanks.
