I don't understand "Unsilenced Air Cleaner"
#2702085
09/29/19 08:41 PM
09/29/19 08:41 PM
Posts: 15,931 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I like the look of the Mopar Unsilenced Air Cleaner from the 60's, but I've never understood the "unsilenced". To me, it appears the top comes all the over the sides and fits fully against the bottom plate, leaving nothing open to the element. I know I must be missing something, because there's not even a snorkel to allow air to come in, and certainly nothing unsilenced with my perception of the way it fits.
Am I just being dense? Wouldn't be the first time.
Facts are stubborn things.
Re: I don't understand "Unsilenced Air Cleaner"
[Re: larrymopar360]
#2702091
09/29/19 08:59 PM
09/29/19 08:59 PM
RapidRobert
I dont have an answer for you but that is a good question
[Re: larrymopar360]
#2702096
09/29/19 09:22 PM
09/29/19 09:22 PM
Posts: 4,755 Moved to N.E. Tennessee
GomangoCuda
Take a closer look at the base. The filter element sits in the flat area at the perimeter. The top is bigger leaving a gap around the bottom for air flow.
[Re: GomangoCuda]
#2702134
09/29/19 11:14 PM
09/29/19 11:14 PM
Posts: 701 Northern California
lilcuda
Northern California
Take a closer look at the base. The filter element sits in the flat area at the perimeter. The top is bigger leaving a gap around the bottom for air flow. This. ^^^
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: lilcuda]
#2702211
09/30/19 10:40 AM
09/30/19 10:40 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Take a closer look at the base. The filter element sits in the flat area at the perimeter. The top is bigger leaving a gap around the bottom for air flow. This. ^^^ This x2 ^^^^^ However, when compared to aftermarket open element filters, the Mopar unit pictured is considerably quieter.
[Re: TC@HP2]
#2702215
09/30/19 10:50 AM
09/30/19 10:50 AM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
To clarify, As stated above, their are two differences, A "normal" air cleaner's lid is sealed to the base forcing the required air to enter through the snorkel which acts as a muffler. Make sense now ?
[Re: BloFish]
#2702662
10/01/19 04:03 PM
10/01/19 04:03 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Ok, I guess if it (the base) seals against the element and not the lid sides, then some extra air comes in the bottom, versus just a snorkel.
Anyone running one of these, can you advise if it's as open sounding as a flipped lid? I kind of want one for my stroked 360 (408) but prefer a stock Mopar air cleaner, although this would not be stock to the car.
Thanks.
[Re: kowalski440]
#2702689
10/01/19 05:08 PM
10/01/19 05:08 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It's definately louder, but not a full throated roar. Maybe if I tested it with a TQ? Ok, thanks. If you decide you're selling one I'd PM me
[Re: kowalski440]
#2702790
10/01/19 10:56 PM
10/01/19 10:56 PM
Posts: 16,530 On the run…
BloFish
On the run…
I might have one available! I’d be happy to buy one for 1990’s prices Let me know...
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: larrymopar360]
#2703086
10/02/19 03:29 PM
10/02/19 03:29 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
it appears the top comes all the over the sides and fits fully against the bottom plate, leaving nothing open to the element. Here's your issue. The filter must be tall enough to allow air to enter under the cover. Thus you will "hear" air being pulled in. You can get the same affect by using too tall of a filter in a regular housing and it will be unsilenced at the top. We did this a lot way back when. Will flow all the air you need, as the can and filter are much larger. I dig where your going with this. Super kool on da truck.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2703144
10/02/19 05:32 PM
10/02/19 05:32 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yes, trying to be secretive about letting the extra air and and having the cool four barrel sound, and keep it Mopar. Also, lately I've been really liking the look of the unsilenced air cleaner more and more. Seeing them atop an old stock hp383 is a beautiful site.
[Re: larrymopar360]
#2703160
10/02/19 06:27 PM
10/02/19 06:27 PM
bboogieart
Lost and Spaced
trying to be secretive about letting the extra air and and having the cool four barrel sound, I had an air filter housing that had a series of holes (about one inch) around the circumference of the bottom, out side the filter. Cant remember what it came off of, Maybe an early 70's big block? The idea is sound so maybe drill 1" holes around the bottom of your air cleaner housing. Wont be sucking cold air from there though. Or like we did back in the fun young days just get a taller filter or stack them.
[Re: poorboy]
#2703683
10/04/19 04:25 AM
10/04/19 04:25 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I have experimented a bit with both styles and the road noise is dramatically louder at freeway speeds with an unsilenced unit vs. a dual snorkel.
