Page 3 of 3 1 2 3
Re: Valve spring pressures and testing [Re: mopar dave] #2701470
09/27/19 04:48 PM
09/27/19 04:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you’re good with buying the gas....... go for it.
Re: Valve spring pressures and testing [Re: fast68plymouth] #2701533
09/27/19 08:17 PM
09/27/19 08:17 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
Yeah I really don't mind. I'm already buying and mixing race fuel anyway. The VP race fuel concentrate that autozone sells in the quart cans works pretty well for longer trips as well. I really think the compression boost will bring the combo together. If the vert needs loosen then i'll get that next year. Like Lenny said, if you loosen the vert now, you might find it too loose after the engine tweaking. I'm confident the spring check and compression boost is the key.
Re: Valve spring pressures and testing [Re: mopar dave] #2701544
09/27/19 08:32 PM
09/27/19 08:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted by mopar dave
Install height per Todd are 1.930 with 145# on the seat and 410# open. Coil binds at 1.200.
Weighed one? Over or under 150 grams?
Re: Valve spring pressures and testing [Re: BradH] #2701549
09/27/19 08:38 PM
09/27/19 08:38 PM
Mt Morris Michigan
Mt Morris Michigan
I have no idea what they weight, but they do have Titanium retainers. I wont be pulling this apart for a couple weeks yet.
Re: Valve spring pressures and testing [Re: mopar dave] #2701553
09/27/19 08:43 PM
09/27/19 08:43 PM
BradH Offline
BradH  Offline
Dual spring with flat damper between the inner and outer coils? If so, more likely to chew up the ti retainers.
Re: Valve spring pressures and testing [Re: BradH] #2701555
09/27/19 08:45 PM
09/27/19 08:45 PM
Mt Morris Michigan
Mt Morris Michigan
I don't recall that. Twin spring with TI retainer. No damper as I recall.
Re: Valve spring pressures and testing [Re: mopar dave] #2701693
09/28/19 11:44 AM
09/28/19 11:44 AM
BradH Offline
BradH  Offline
My favorite solid flat-tappet spring for .600"+/- lift was the Lunati 73121 (no idea who the manufacturer is, or if the same spring is offered by other companies). Some were made as dual springs w/dampers, others were dual springs w/o dampers (interference fit), but the part # was always the same. I had some of both style, but preferred the no-damper style since they didn't chew up the ti retainers I liked to use.
1.540 Outer spring OD
1.140 Outer spring ID
.860 Inner spring ID (no damper version)
.794 Inner spring ID (w/ damper version)
Advertised pressures:
Closed - 142# at 1.940
Open - 402# at 1.250
Rate - 377 #/in
Coil bind - 1.089
The other thing I liked about them was they're light: 126 g (no-damper version) vs 153 g for COMP 928/930 dual w/ damper. Even the w/damper version was still about 20 grams lighter than the 928/930.
I don't have any more new sets because I sold off my spares when I switched to a solid roller. If you ordered them new today, I suspect they'd be the w/damper version, based upon the current product description.
Page 3 of 3 1 2 3
