Bore size needed on Cometic head gasket #2701459
09/27/19 04:19 PM
09/27/19 04:19 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I think I may have asked this before, but what is the minimum head gasket bore that can be used on a Lo Deck with a 4.375 bore? This is a 511 biuld.
Re: Bore size needed on Cometic head gasket [Re: mopar dave] #2701481
09/27/19 05:24 PM
09/27/19 05:24 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Cometic told me .015" to .030" back from the bore.
2011 Drag Pak Challenger
Re: Bore size needed on Cometic head gasket [Re: rickseeman] #2701535
09/27/19 08:23 PM
09/27/19 08:23 PM
Mt Morris Michigan
Mt Morris Michigan
Cool. Cometic has a head gasket that has a 4.410 bore and a .045 thickness for my 4.375 bore. That's perfect and saves the head from so much metal removal. It will give .043 quench inline with pin and .031 with piston rocked in bore.
Re: Bore size needed on Cometic head gasket [Re: mopar dave] #2701541
09/27/19 08:29 PM
09/27/19 08:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
A 4.410 won't work with the Hughes CNC chambers; go with the 4.500.
Re: Bore size needed on Cometic head gasket [Re: BradH] #2701546
09/27/19 08:33 PM
09/27/19 08:33 PM
Mt Morris Michigan
Mt Morris Michigan
No kidding. Ok, thanks for letting me know Brad. Saved me $200. I'm using the 4.500 now with a .051 thickness.
Re: Bore size needed on Cometic head gasket [Re: mopar dave] #2701556
09/27/19 08:46 PM
09/27/19 08:46 PM
BradH Offline
BradH  Offline
Yep, a 4.410 clears the bore OK, but the fire ring overhangs the edge of the chamber. I checked mine with both sizes to be sure.
Re: Bore size needed on Cometic head gasket [Re: BradH] #2701557
09/27/19 08:51 PM
09/27/19 08:51 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks again Brad, that was a good catch. Back to the drawing board.
Re: Bore size needed on Cometic head gasket [Re: BradH] #2701564
09/27/19 09:06 PM
09/27/19 09:06 PM
Mt Morris Michigan
Mt Morris Michigan
I can still get 12.44:1 with the 4.500 gasket, close enough. It will require removing .045 from the head. The decks on these heads are super thick at .650".
What are engine builders now getting away with as far as the quench distance on large bores like 4.375 is concerned? .038, .040? and more importantly piston rocked quench on each side of the pin?
