Ambient LED Lighting Footwell Kit - how to wire? #2700824
09/25/19 03:20 PM
09/25/19 03:20 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
I would like to add a led footwell lighting kit. What would be the correct way to wire/tie this in so it operates the same as the dome light? I think the wiring is a little goofy like the door switch controls the ground not the hot, but I am not entirely sure. Current draw is a 1/3 of an amp so I am not too concerned with overloading a circuit. This would be for a '70 Challenger if it matters.
https://www.oraclelights.com/collec...oracle-ambient-led-lighting-footwell-kit
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: challenger70] #2700844
09/25/19 04:06 PM
09/25/19 04:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It has positive and negative wiring so fed it a 12v always hot source and wire the negative into the door switch ground.
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: stumpy] #2700853
09/25/19 04:40 PM
09/25/19 04:40 PM
west palm beach, florida
modelmakerinc Offline
iagree
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: modelmakerinc] #2700861
09/25/19 05:03 PM
09/25/19 05:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
some of those Chinese leds are picky as to which is pos and which is neg so it's best to test them with your battery as to which wire is pos and which is neg. Don't rely on color coding. If they don't light when you hook the two wires to the battery then try reversing the wires.
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: stumpy] #2700864
09/25/19 05:10 PM
09/25/19 05:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Also you can do way better on the price if you check around on EBay. Here's an example. They would work with the door switch. https://www.ebay.com/sch/i.html?_fr...p;_nkw=footwell+led+lights&_sacat=0. If you don't want to wait for Chinese shipping then select North America on categories list on the left side of the page.
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: stumpy] #2701052
09/26/19 09:54 AM
09/26/19 09:54 AM
Berwyn, IL
Berwyn, IL
Thanks for the help! Does it matter which door switch? does it need to be both?
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: challenger70] #2701088
09/26/19 11:36 AM
09/26/19 11:36 AM
moparx Offline
moparx  Offline
it needs to be both. if you only connect to one, say the driver's door, they will only light when you open the driver's door.
beer
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: moparx] #2701136
09/26/19 01:43 PM
09/26/19 01:43 PM
ILL
Greentween Offline
Greentween  Offline
ILL
The dome light circuit connector is accessible from the trunk, above the left rear inner fender. (at least that's where it is on my 74).
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: Greentween] #2701162
09/26/19 03:17 PM
09/26/19 03:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Door switch's are much easier to get to.
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: Greentween] #2701193
09/26/19 04:58 PM
09/26/19 04:58 PM
Berwyn, IL
Berwyn, IL
I will think about that... good idea that's where the trunk light gets power from too.
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: moparx] #2701221
09/26/19 07:45 PM
09/26/19 07:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
Aren't the door switches tied in parallel along with the dome light switch on the instrument lamps ??? beer
Re: Ambient LED Lighting Footwell Kit - how to wire? [Re: TJP] #2701347
09/27/19 09:55 AM
09/27/19 09:55 AM
moparx Offline
moparx  Offline
beer
that could be a possible "it depends" situation. i have fixed too many wiring issues over the years, i just can't remember.
even so, i "think" hooking into the door switches would still make the footwell lights work with the dome light switch on the dash. [maybe]
beer
