Re: old Purple shaft identification
[Re: Moparnut426]
#2701072
09/26/19 10:45 AM
09/26/19 10:45 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
The very oldest ones like yours really need to be measured.
The paint dot/stripe markings on them, although documented by Mopar many years ago (never published publicly) have been proven wrong time and time again. By the time I came across the 6th or 7th one that had specs that didn't match the paint codes, that was enough for me.
Later ones have engraved markings and are easier.
The easiest way to do it is put it back in the motor, with one lifter set up a degree wheel and an indicator, and measure lift and duration.
Rich H.
Esse Quam Videri
[Re: Moparnut426]
#2701095
09/26/19 11:46 AM
09/26/19 11:46 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Usually just knowing the lift is all you need to figure out what you have, since they all have different lifts.
[Re: fast68plymouth]
#2701099
09/26/19 11:50 AM
09/26/19 11:50 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Usually just knowing the lift is all you need to figure out what you have, since they all have different lifts. Just throw a dial caliper on the lobe...measure the base circle and then the top of the lobe. Subtract the base from the lobe, then multiply by 1.5 = lift.
[Re: an8sec70cuda]
#2701108
09/26/19 12:11 PM
09/26/19 12:11 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How can you distinguish between a hydraulic cam and a solid cam. I have a couple purple shaft small block cams I plotted out in a old block that I would like to sell then moved on to another project I never finished
[Re: pittsburghracer]
#2701111
09/26/19 12:12 PM
09/26/19 12:12 PM
an8sec70cuda
Like Dwayne said...if you could figure the lift on it, it'd be pretty easy to determine which cam it was. As for looking at a cam and telling if it was a solid or hydraulic...I dunno. I'm sure some may know a way, but I don't.
