Re: Drag Week 2019....The Dart from Sweden!!!!!
[Re: justinp61]
#2702569
10/01/19 11:06 AM
10/01/19 11:06 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Wonder if the 1.38 was tripped w/ the back tires? That would be about right...a high 1.2x sixty foot.
[Re: an8sec70cuda]
#2702579
10/01/19 11:29 AM
10/01/19 11:29 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Wonder if the 1.38 was tripped w/ the back tires? That would be about right...a high 1.2x sixty foot. Yep, about a tenth in a 9 sec car. Probably 1.26-1.28 real sixty foot
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: an8sec70cuda]
#2702612
10/01/19 01:01 PM
10/01/19 01:01 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Wonder if the 1.38 was tripped w/ the back tires? That would be about right...a high 1.2x sixty foot. Probably, I didn't think about that.
[Re: justinp61]
#2702645
10/01/19 02:34 PM
10/01/19 02:34 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That run was a thing of beauty.
Motor is just singing.
I’m surprised at how much time he has between gears.
[Re: fast68plymouth]
#2702676
10/01/19 04:37 PM
10/01/19 04:37 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2702808
10/02/19 01:49 AM
10/02/19 01:49 AM
Posts: 28 Germany
stickman60
Germany
It would be nice to know what the shift RPM and RPM drop is on each gear change work According to my eyesight and playing the video in slo mo he leaves at 7200RPM, shifts at 9100RPM , drops to 7100 and winds it out to 9000-ish again. Goes through the traps @8000RPM.
[Re: stickman60]
#2702823
10/02/19 07:19 AM
10/02/19 07:19 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
It would be nice to know what the shift RPM and RPM drop is on each gear change work According to my eyesight and playing the video in slo mo he leaves at 7200RPM, shifts at 9100RPM , drops to 7100 and winds it out to 9000-ish again. Goes through the traps @8000RPM. That was also on Day 5 after 750 miles of street driving and racing 4 other days. Impressive for sure.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2702936
10/02/19 10:02 AM
10/02/19 10:02 AM
Posts: 5,160 Texas
dannysbee
Texas
The engine he is using was designed to run 5-6 hundred miles at over 9000 rpm. Seems to love the stick. I think it a fun x2 car. Fun to watch and fun to drive. One fine drag week car.
Getting old just means you were smarter than some and luckier than others.
#2703024
10/02/19 12:58 PM
10/02/19 12:58 PM
an8sec70cuda
I’m surprised at how much time he has between gears. Pretty sure I watched the video 10 times on repeat the first time I clicked on it, lol. I could just listen to it all day.
