Ebody side door glass; hardtop versus ragtop #2699964
09/22/19 09:17 PM
09/22/19 09:17 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang. Friend brought to my attention that maybe there is a difference in the side door glass between a E-body hardtop and convertible? Here is a side door glass from what I believe is from a 70 Barracuda ragtop.
Troy
Houston Mopar Connection Club
Re: Ebody side door glass; hardtop versus ragtop [Re: hemi68charger] #2699972
09/22/19 09:39 PM
09/22/19 09:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have both conv and hardtop and just looked at them and if they're diff it's really subtle, I think they are the same.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Ebody side door glass; hardtop versus ragtop [Re: HemiRick] #2699977
09/22/19 09:50 PM
09/22/19 09:50 PM
Houston, Tx
Houston, Tx
So they measure the same from top of door to top of glass with the window in the up position? Just checked out AMD's site real quick, looks like there is a difference, maybe inside the door.. Will check my parts book later on this week....
Cheers,
Troy
Re: Ebody side door glass; hardtop versus ragtop [Re: hemi68charger] #2699983
09/22/19 10:20 PM
09/22/19 10:20 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Eazy-Peazy. Conv's have a sharp corner at the upper front corner. No need for p/n's
Re: Ebody side door glass; hardtop versus ragtop [Re: hemi68charger] #2699985
09/22/19 10:29 PM
09/22/19 10:29 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
E-body convertible door glass ( pictured by poster ) is same Cuda and Challenger, identifiable by squared front top.
E-body hardtop door glass is the same Cuda and Challenger, identifiable by rounded front top corner.
That is the easiest way to spot the difference in the two
Hardtop 1/4 glass is different Cuda verses Challenger.
And... convertible 1/4 glass is different Cuda verses Challenger... and both are different than hardtop.
Re: Ebody side door glass; hardtop versus ragtop [Re: mccannix] #2699988
09/22/19 10:34 PM
09/22/19 10:34 PM
Houston, Tx
Houston, Tx
Thanks guys.. Nope.. Clear to me.. Makes.sense...👍
Troy
Re: Ebody side door glass; hardtop versus ragtop [Re: hemi68charger] #2700013
09/23/19 12:29 AM
09/23/19 12:29 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Hardtop door and quarter glass have a rounded edge vs. the angular edge of the convertible glass. Here's a photo of the convertible rear quarter glass on left as compared to hardtop rear quarter glass on right.
Terry
Re: Ebody side door glass; hardtop versus ragtop [Re: mccannix] #2700028
09/23/19 07:10 AM
09/23/19 07:10 AM
London, England
Gavin Offline
Gavin  Offline
London, England
OK, one of us is misremembering - I believe the vert quarterglass is the same for Challenger and Cuda, the hardtop quarterglass is different.....
Re: Ebody side door glass; hardtop versus ragtop [Re: Gavin] #2700038
09/23/19 08:16 AM
09/23/19 08:16 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Gavin...yes you are correct there , same 1/4 glass for Cuda/Challenger convert.
71vert340....you are partially correct, but only Challenger hardtop 1/4 glass has rounded edge
.. Cuda hardtop quarter glass has a squared edge but not the same squared contour as convertible
Re: Ebody side door glass; hardtop versus ragtop [Re: 71vert340] #2700289
09/23/19 10:16 PM
09/23/19 10:16 PM
Houston, Tx
Houston, Tx
Terry
The door glass is different too, correct? I believe someone said it was.. Nice visual on the rear side glass... Thanks... up
Troy
Re: Ebody side door glass; hardtop versus ragtop [Re: hemi68charger] #2700316
09/24/19 01:26 AM
09/24/19 01:26 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Convertible door and quarterglass are different from hardtop glass.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Ebody side door glass; hardtop versus ragtop [Re: chargervert] #2700576
09/24/19 07:54 PM
09/24/19 07:54 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
As Mccannix pointed out in my earlier post, my photos showed the difference between the rear Challenger glass. Here's a photo of Challenger clear convertible door glass on left to hardtop tinted glass on right. Difference in front top corner is apparent.
Terry
