Page 128 of 159 1 2 126 127 128 129 130 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26998
02/27/07 10:20 AM
02/27/07 10:20 AM
Beaverton, OR
StevesBug Offline
StevesBug  Offline
Beaverton, OR
This is what I've used.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: StevesBug] #26999
02/27/07 11:30 AM
02/27/07 11:30 AM
toronto canada
69chargeryeehaa Offline OP
toronto canada
Here's what i use:
i really like the one rounded edge, and the other flat edge, it lets you cut in places like the door/fender gap perfectly!!!
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: StevesBug] #27000
02/27/07 02:14 PM
02/27/07 02:14 PM
Do you see any advantage to using a 6 inch wide one compared to Chargers 4 inch wide one ?
Beaulieu
Re: Paint job on a budget!? CONTINUED..page 44........ #27001
02/27/07 04:13 PM
02/27/07 04:13 PM
Beaverton, OR
StevesBug Offline
StevesBug  Offline
Beaverton, OR
"Do you see any advantage to using a 6 inch wide one compared to Chargers 4 inch wide one ?"
No...in fact the smaller size would make the job easier in the fender/body joints and some areas around the windshield. The larger goes quicker on the roof etc.
My lack of experience was a much bigger issue.
Re: Paint job on a budget!? CONTINUED..page 44........ #27002
02/27/07 06:23 PM
02/27/07 06:23 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Beaulieu
I had experimented with the 6" high density and I found myself liking the 4" high density better.
You are able to apply a more even pressure to the 4 inch compared to the 6"... I also found that the 4 inch was better at maneuvering around ALL the surfaces on a car.
The 6" tends to be harder to get an even amount of paint on to the roller. So you find yourself having to roll over the same surface repeatedly to get one even layer laid down.
So stick with the 4"... because my experiments indicated that in this case 'smaller' is 'better'
And that was while experimenting with both Tremclad/Rustoleum and Brightside.
Marq
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Marq] #27003
02/27/07 06:52 PM
02/27/07 06:52 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
4" work just fine for me
Re: Paint job on a budget!? CONTINUED..page 44........ #27004
02/27/07 07:21 PM
02/27/07 07:21 PM
Stevesbug,
Has anyone else run into these spots ? Any suggestions ?
Yes, I had the same problem with the black Rustoleum Pro on my test fender, I attributed it to not wetsanding all of the orange peel out of the underlying layers.
I've only done the test panel so far...
That is the result of sanding thru the top coat of paint into the ones beneath it. The splotches are definitely more pronounced if you didnt sand the underlying coat. I have avoided getting these by wet sanding the last 4 coats with 2000 grit.
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27005
02/27/07 07:29 PM
02/27/07 07:29 PM
Thought I would pop in to post some progress pics. I have been roller painting body panels one at a time in my basement over the winter. I have started to reassemble the truck and the front clip is almost done. Had some troubles with the hood where I accidentally sanded to primer on some sharp edges so I am starting over on it
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27006
02/27/07 07:31 PM
02/27/07 07:31 PM
oops, forgot the picture.
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27007
02/27/07 07:33 PM
02/27/07 07:33 PM
Another.
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27008
02/27/07 08:22 PM
02/27/07 08:22 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
What kind/color paint is that Bob? Looks sweet.
Re: Paint job on a budget!? CONTINUED..page 44........ #27009
02/27/07 08:45 PM
02/27/07 08:45 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Bob looks great did you end up using the Regal Red?
Now if only it was a mopar
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #27010
02/27/07 09:59 PM
02/27/07 09:59 PM
Yep, It's Regal Red Rustoleum. About 8-10 coats per panel, final wet sand with 2000 grit and buffed with 3M Perfect it Foam Polishing Pad Glaze on a wool pad. The paint is still pretty soft and prone to damage when a wrench slips, probably because it hasent seen a temperature above 55 deg yet between the basement and outside here.
Here is a link to the project with more paint pics:
Truck Project
You know, if I take off my glasses and squint my eyes that Dodge P/U looks just like a GMC
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #27011
02/28/07 01:45 AM
02/28/07 01:45 AM
the "leopard" spots you are getting is burn through from the looks of it. you sanded the top coat too much and the bottom is showing through.
Re: Paint job on a budget!? CONTINUED..page 44........ #27012
02/28/07 10:29 AM
02/28/07 10:29 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Bob, my hat is off to you guys that take a car or truck down that far then bring it back, nice job
Re: Paint job on a budget!? CONTINUED..page 44........ #27013
02/28/07 01:31 PM
02/28/07 01:31 PM
Beaverton, OR
StevesBug Offline
StevesBug  Offline
Beaverton, OR
Bob,
The finish on your door is what I'm after, it's beautiful !
I know I can get the shine, so I guess another coat or 2 and sand only with 2000.
Re: Paint job on a budget!? CONTINUED..page 44........ #27014
03/01/07 01:15 AM
03/01/07 01:15 AM
i have a few of those also from buffing and how do i get rid of them?
Re: Paint job on a budget!? CONTINUED..page 44........ #27015
03/01/07 01:48 PM
03/01/07 01:48 PM
Kansas
dalbers Offline
dalbers  Offline
Kansas
Hey Bob, have you posted your progress on the 67-72 truck forum yet? I'm getting ready to start on my 69 long bed used the brightside. Yours is looking great.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27016
03/02/07 03:07 AM
03/02/07 03:07 AM
OK, I've read most all of the pages on this second section and came to the conclusion using Brightside was the way to go for more reasons than 1.
My truck used to be army green (spray painted, pain in the crapper) and the green paint was fading pretty bad on the hood and roof. Had to look for another option so I just went back to black since that's what color the truck used to be.
I got so excited to paint the truck that I just went over everything right off the bat. I kind of regret doing that but it had to be wet sanded anyway since I didn't thin the paint out. After 3 coats I decided to try my hand at wet sanding. At first I used 1500 grit on my sanding block but that didn't take the orange peel out as fast as I had liked so I switched to 1000. Worked much better and the paint still had a pretty good shine to it (I could see it shine in my side mirrors driving down the freeway at night).
After wet sanding all of the orange peel out, I actually decided to put on another coat but thin it out this time with mineral spirits. Let me tell you something, I'm GLAD I thinned the paint out. Orange peel is much less than it was before and some spots actually have no orange peel.
At this point, I'm about 75% happy with how the paint looks. It looks good now but I know how good it can be with a little more work. I think I just decided to wet sand again and polish it up. The reason why I didn't just polish after the 3rd coat is because in some spots, the green was showing through. Anyway, onto some pictars
And some getting it dirty
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: dalbers] #27017
03/02/07 02:39 PM
03/02/07 02:39 PM
Not yet, I am going to wait a while until the cab is done and I start the bed restoration. I am still having trouble with the center ridge of the hood. I once again got too aggressive with the wet sanding and cut thru to the primer. To make things worse I thought I would touch-up that area with a spray can of Regal Red. DONT DO THIS! The spray paint will soften the rolled on paint and even made it blister. Back to square one.
Bob
