Re: Dana 60/70 housing repair tool Alberta
[Re: Uberpube]
#2699146
09/20/19 07:18 AM
09/20/19 07:18 AM
Posts: 5,829 ohio
ruderunner
ohio
Hard to tell in the pic but im not sure that's damaged vs maching marks. The surface for the od of the cup looks ok. How does the old cup look?
Is a new cup a loose fit?
Was backlash excessive originally?
Angry white pureblood male
[Re: Uberpube]
#2699547
09/21/19 03:30 PM
09/21/19 03:30 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I thought about shimming it out, a local diff shop said they've had no luck with doing that and won't do it as the bearing wears prematurely as there's no guarantee it's sitting true as the ridge matches the old cup footprint. They do complete banjo replacements instead of trying to fix the surface, which is also big money. I'm not talking about shimming it out. They make a spacer that will go in between the race and the housing that prevents it from wearing the housing.
[Re: Uberpube]
#2699931
09/22/19 07:27 PM
09/22/19 07:27 PM
Posts: 2,046 ky.
kenworth_goose
ky.
This is already worn on both sides, a spacer isn't going to fix the problem I have. The spacer is actually made for this problem. They come in different thicknesses.
[Re: kenworth_goose]
#2699940
09/22/19 08:11 PM
09/22/19 08:11 PM
Posts: 703 Southern Alberta
Uberpube
Southern Alberta
This is already worn on both sides, a spacer isn't going to fix the problem I have. The spacer is actually made for this problem. They come in different thicknesses. I think I found what you are talking about its part DS42563, its a spacer if you have a Wide 60 carrier and are fitting a narrow case into it.
