Re: Help---Mystery problem !! [Re: racerhog] #2708196
10/18/19 08:31 PM
10/18/19 08:31 PM
gregsdart Offline
gregsdart  Offline
If you are using any of the factory wiring that could do it. The ignition should be all new wiring and soldered connections, leave nothing to chance. Grounds can go bad real quick. I had a battery to engine ground cable corode in less than two years and the car wouldn't crank!
Re: Help---Mystery problem !! [Re: gregsdart] #2708567
10/20/19 02:45 PM
10/20/19 02:45 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Keep Chipping at it..... You will get it handled !!!!!!!
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Help---Mystery problem !! [Re: racerhog] #2708609
10/20/19 05:11 PM
10/20/19 05:11 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
possible that something else other than the fuseable link burned up?
weird for 2 different boxes getting so hot, you have a true Gremlin there
Good luck
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
