B1 question #2695671
09/09/19 08:38 AM
09/09/19 08:38 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
Thinking about doing a B1 build however, I would like to use the indy nss intake. I've seen it done. But I'm not sure how it's done. Any help and /or pictures would be great.
Re: B1 question [Re: e85mope] #2695762
09/09/19 12:14 PM
09/09/19 12:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Its a LOT of work and you will have as much money as a sheet metal intake when you are done. I talked to "the man" about it a few weeks ago. I thought you guys could run sheet metal stuff?
Re: B1 question [Re: Al_Alguire] #2698100
09/16/19 02:39 PM
09/16/19 02:39 PM
TEXAS
Panty Dropper Offline
TEXAS
What kind of B1 Motor do you plan on building? Low compression, High Compression, N/A, Nitrous, Blown, Boosted, Pro-charged?
I just re-did my 605 Nitrous motor. De-Stroked it to a 562 and went Carbureted with an F1X-12 hanging off the front of it.. smile
Re: B1 question [Re: Panty Dropper] #2698191
09/16/19 07:25 PM
09/16/19 07:25 PM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
572 14:1 nss motor on One Ethanol. Oneethanol.com
Re: B1 question [Re: e85mope] #2698195
09/16/19 07:38 PM
09/16/19 07:38 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had an APD 1250’built for my B1 headed 572 but did some wheeling dealing with them for an 1150 alcohol carb which I should receive soon if I decide to Bracket Race this car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B1 question [Re: pittsburghracer] #2698213
09/16/19 08:28 PM
09/16/19 08:28 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Sheetmetal intake is $3500.00+ $$
Adapter plates is your only option to use a Indy Crossram with B1 heads.
I dont think anyone is making them anymore.
Re: B1 question [Re: Sammy] #2698218
09/16/19 08:49 PM
09/16/19 08:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
By the time you are done you will have that in it, unless you own a machine shop can weld cast aluminum, have some mad skillzzz and don't value your time. Then you will still have a compromise on the intake, way more so than sheet metal. But it CAN be done and there are a couple out there and they paid dearly.
B1 head and Indy head share NOTHING in common other than bolt pattern on the block. The intake bolt spacing is different as is the intake face angle between the two heads. Not to mention port size and shape.
Re: B1 question [Re: Al_Alguire] #2698297
09/17/19 06:58 AM
09/17/19 06:58 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
IIRC the rules are the plenum can be sheetmetal but the runners have to be cast. At least for NSS. Best Machine makes adapters for B1 to Indy manifolds. I saw a cast B1 tunnel run for sale on one of the Mopar Facebook pages.
Re: B1 question [Re: fbs63] #2698413
09/17/19 11:49 AM
09/17/19 11:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I believe it depends on which NSS class. The FX classes allow for sheet metal stuff, at least NMCA wise. I believe that's where the OP is looking to run.
Re: B1 question [Re: e85mope] #2698464
09/17/19 02:03 PM
09/17/19 02:03 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
IF I WERE YOU...lol
Anyway, you might look at DVW Doug's combo that makes 900HP with 440-1 heads in a 572 ...STILL USING AFB's on that same INDY crossram. That is a pretty simple and easily duplicable combo which is also pretty maintenance friendly.
Re: B1 question [Re: fbs63] #2698536
09/17/19 06:41 PM
09/17/19 06:41 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Yep, Chuck makes adapters for this.
Casey FJ
Re: B1 question [Re: HardcoreB] #2698872
09/19/19 08:04 AM
09/19/19 08:04 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What happened to Orig poster? I thought he was "thinking about" switching to a B1?
Re: B1 question [Re: Whompin_Wedge] #2698924
09/19/19 10:26 AM
09/19/19 10:26 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
I called and talked to Chuck @ Best Machine. He said he has been out of the adapter business for a while and won't be making anymore.
Re: B1 question [Re: HardcoreB] #2698928
09/19/19 10:31 AM
09/19/19 10:31 AM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
I'am putting together a B1 for NSS. It ought to be interesting to say the least. I have a sheet metal intake now, but would rather run the indy inline cross ram. BTW.. If anyone is looking for Indy 3x intake, comp 829 lifters, or rods and pistons for a 572, check the race parts for sale section. smile
Re: B1 question [Re: e85mope] #2698931
09/19/19 10:38 AM
09/19/19 10:38 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Good luck finding a set.
Those adapters are like gold now.
Re: B1 question [Re: Sammy] #2698971
09/19/19 01:04 PM
09/19/19 01:04 PM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
I'm starting to find that out. I may just end up making my own.
Re: B1 question [Re: e85mope] #2698977
09/19/19 01:37 PM
09/19/19 01:37 PM
PA.
"Little"John
"Little"John
PA.
Not sure he can help you but give Tom a call.
http://www.hemphillracingengines.com/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 question [Re: pittsburghracer] #2698980
09/19/19 01:55 PM
09/19/19 01:55 PM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
I just left Tom a message. Thanks for the referance
Re: B1 question [Re: e85mope] #2698990
09/19/19 02:33 PM
09/19/19 02:33 PM
PA.
"Little"John
"Little"John
PA.
Hope it helps. I’ve known and raced with Tom for over 40 years. He even has on his website that he makes different spacers. Tell him John Cadamore said hi.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 question [Re: e85mope] #2700139
09/23/19 01:27 PM
09/23/19 01:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
[quote=e85mope][quote=HardcoreB]
Like I said earlier......
